Thread: Charge system failure light
Results 1 to 4 of 4
  1. #1 Charge system failure light
    Aug 2013
    Waterboro, ME
    I have noticed on my 04 comp g that at certain times especially at night when the headlights r on that certain things drain my battery more. For example trying my rear windows causes my headlights to dim and my battery meter drops ro 13 to 13.5 volts and thats when the charge system failure light comes on. Any ideas?
  2. #2 Re: Charge system failure light
    Alternator sounds like its dying if the you are seeing these problems.
    The alternator should be able to keep up with small loads on the system like you are doing. A quick drop in voltage but then bounce right back to the same if not higher voltage to keep up and level out near 13.5 to 14v.
    Wouldnt hurt to check battery cables and such for problems, clean them all and the grounds and see if that helps.
  3. #3 Re: Charge system failure light
    Aug 2013
    Waterboro, ME
    Normal idling is ar o und 14.5 volts and driving runs between 14.3 to 15.10
  4. #4 Re: Charge system failure light
    Try cleaning and making sure stuff is tight first and then just keep an eye on things.
    We had a 05ish grand prix in the shop one time that went through 3 alts with this issue before the 4th alternator stopped the problem.
  1. Charging System Failure
    By Chadgervais in forum General Grand Prix Discussion
    Last Post: 01-03-2013, 11:51 AM
  2. Charging System Failure Help??
    By 2005GrandPrix in forum Audio, Security & Visual Electronics
    Last Post: 06-09-2012, 06:19 PM
  3. Charging system failure w/HID's
    By zx7r4u2nv in forum General Tech Discussion
    Last Post: 03-12-2011, 12:37 AM
  4. Charging System Failure
    By FriboRage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-22-2010, 12:29 AM
  5. Charging System Failure
    By missyfisch in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-08-2009, 10:27 AM
