Thread: low end knock/rattle
Results 1 to 7 of 7
  1. #1 low end knock/rattle
    Detroit
    Ok, I have a 02 gtp, stock, it has a low end knock/rattle, I have knowledge of rod knocks since I've had 2 in my 97 gtp that I used to own, this sounds similar but not the same.
    The 97s symptoms were lose of power, heavy knocking sound, low oil light, knock traces rpms. My 02 has no power loss whatsoever, the supercharger squeals the tires no problem, no SES or any lights, sounds at idle are lighter than a rod knock and when rpms increase it's more of a rattle (like shaking a can with a metal ball/bearing in it) it's not random knocking, it's rhythmic.
    I think it may be something in the trans, or attached to the trans (flexplate, torque converter bolt maybe?) My trans has lost it OD as well but that's because it wasn't hardened when made by the manufacturer.
    Btw, to give perspective, when my 97 got it's first knock the engine cracked within a month, the second knock was fixed due to warranty which happened in a swapped block 2 months later. My 02 has been knocking/rattling since June, sooo Yeh.
  2. #2 Re: low end knock/rattle
    I assumed you check the oil for sparkles, to make sure its not a bearing.
    Take the belts off one at a time and see if the noise is still there.
    You can also make sure the torque converter bolts are tight.
  3. #3 Re: low end knock/rattle
    Detroit
    Also FiveFingerDeathPunch... Great band.
  4. #4 Re: low end knock/rattle
    Detroit
    I've changed the oil numerous times, no stripper glitter [THANK GAWD], by taking the belts off I assume you mean the supercharger belt, then accessory belt, cause holding the belt off of a pulley seems pretty 'hand cutty-offy', also how would I see if the bolts are tight without dropping the trans? Thx.
  5. #5 Re: low end knock/rattle
    Oct 2013
    Dayton, Ohio
    Sure it's not a motor mount? I get a knock at idle in gear....mounts.
  6. #6 Re: low end knock/rattle
    Take the belt(s) off before starting it, just to see if the noise stops. Then you'd know if the sound is coming from something being ran off the belts.
    There is a cover that you remove on the bottom of the motor, you'll see the flexplate and thats where you will also see the torque converter is bolted to the flexplate. Spin the motor by hand in "N", that way you can see if all the bolts are tight.
  7. #7 Re: low end knock/rattle
    Detroit
    update: I also forgot to mention, that when the car is warming up the Knock/ rattle becomes more audible its not present at startup
  1. rattle can job
    By mthorn11 in forum Visual/Body Modifications
    Last Post: 06-29-2013, 10:07 PM
  2. Strange rattle/knock
    By BD3511 in forum General Tech Discussion
    Last Post: 06-21-2013, 07:46 PM
  3. Low end rattle
    By kenconerly in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2013, 12:03 PM
  4. 01 GTP Engine Rattle/Knock
    By Gizmo669 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-16-2012, 12:10 PM
  5. Listen to the knock knock knock....
    By Lsick7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2011, 05:40 PM
