Thread: YELLA TERRA Intercooler kit?
Results 1 to 8 of 8
  1. #1 YELLA TERRA Intercooler kit?
    GTP Level Member rodguezsciii's Avatar
    Sep 2012
    Anybody have any experience with them? ....vs ZZP or WBStore?)
  2. #2 Re: YELLA TERRA Intercooler kit?
    Sep 2012
    $1350
    Yella Terra’s vast experience with supercharger kit design and water to air intercooler technology has culminated in the release of the new highly efficient V2 intercoolers to suit the popular GM 3800 supercharged V6.
    Unique V-2 intercooler core designs maximise surface area for efficient heat transfer away from the intake charge with minimum interference to air flow. The single pass water flow design incorporated in the Yella Terra intercooler delivers superior water flow rates and 100% cold water to the core. This dramatically improves cooling efficiency compared to alternative counter flow heater cores where 50% pre heated water is returned through the core. To eliminate any heat transfer from engine to the intercooler core, the V2 CNC machined billet alloy body features rubber core mounts to completely isolate it from engine heat.
    The billet alloy CNC machined mounting plates provide superior sealing to the supercharger and intake manifold. All alloy construction of the V2 system will not warp, buckle or crack on installation like some composite materials used in other brands which also become brittle when exposed to engine oil and heat. An equally efficient alloy front mount heat exchanger and coolant reservoir combined with reliable electric pump and O ringed assembly plumbing are included in the intercooler kit for easy fitting. One of the major benefits of the V2 intercooler designs is they are very low profile and can fit under the factory GM V6 supercharger with no hood modifications.
    • V 2 STEALTH-Appropriately named, this kit is very low profile and virtually undetectable under a factory supercharger. The Stealth kit uses the original fuel rails and cover for that OEM look. Despite its size, Stealth has efficiency to easily handle moderate boost upgrades.
  3. #3 Re: YELLA TERRA Intercooler kit?
    Omaha, NE
    I'd say its not worth it considering you can find used IC kits on the forums for under a third of the price.
  4. #4 Re: YELLA TERRA Intercooler kit?
    Mercer, Pa
    Sounds like a zzp short stack.
    Compared to full size intercoolers
    100% same amount of labor to install
    50% cost
    25% performance increase
  5. #5 Re: YELLA TERRA Intercooler kit?
    GTP Level Member Silver2kgtp's Avatar
    Feb 2008
    NY
    I wouldn't pay that price for the thinness of that core. Does look like a SS IC.
    http://s1292.photobucket.com/user/si...d%20Prix%20GTP
    10.99 @ 121.99 1.74 60' (Ran out of fuel : +18 AFR)NO SPRAY!!!
  6. #6 Re: YELLA TERRA Intercooler kit?
    Sep 2012
    I'd never pay the full price for it....just never heard of any other IC set up other than ZZP/Wbody and the Phenolic IC sold individually by SSEI....saw this floating on Facebook, wondered if anyone else knew anything about them....
    Quote Originally Posted by sseilmnop View Post
    50% cost
    ^^I didn't even notice how thin it was until you mentioned it....
    Quote Originally Posted by Silver2kgtp View Post
    ^^^x2....
  7. #7 Re: YELLA TERRA Intercooler kit?
    Mercer, Pa
    Got a link or picture for the Facebook intercooler.
  8. #8 Re: YELLA TERRA Intercooler kit?
    Sep 2012
    that exact picture and paraphrase of the Yella Terra IC is the one I'm talking about...it was posted as a Facebook only deal for $1350.....it was on Yella Terra's official Facebook page....
  1. Hi Guys from Yella Terra
    By YT Tech in forum Introductions/Noob Questions
    Last Post: 10-29-2009, 06:30 PM
  2. Yella terra's vs. zzp's modded rockers
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-23-2009, 08:41 AM
