Are you trying to take it off to replace the caliper? I know the pregen grand prix's parking brake was internal to the caliper. There was a little pin at the end of the cable, and you had to activate the parking brake at the caliper with your hand, and wiggle the pin out. Or just remove the caliper first and try it with it off. I'm not sure if the 04+ style is that way or not. I've never done brakes on one of them.
just checked the 05 build options; there were 2 different e-brake caliper options. jl9, j65 had the ebrake as part of the calilper and the z7u had the ebrake in the rotor hat.
getting the cable out the service manual way is a big time waster because the equalizer nut and cable connector clips will be seized. I'm with 02navyblue; remove the cable lever at the caliper and wiggle the cable out. bend the crap out of the old lever arm if needed as it won't be re-used anyway. install the cable on the new caliper before installing the caliper to the caliper bracket. This will give you the slack in the cable needed to get it on the lever arm.
This is why you loan-a-tool and do this job in 30 minutes.
What was the problem?
Sent from my SAMSUNG-SGH-I747 using Tapatalk
So I believe I now have another caliper seized on my car. I believe its my left one because I just had my rear right done. Anyone know why this is happening. Is it just because its the 2nd year for that body style?
