Thread: hv3 install
Results 1 to 20 of 31
  1. #1 hv3 install
    Jul 2011
    Baltimore, MD
    Ok.just received my hv insert and put it on. Now im throwing three codes 300, 171, 1380. I checked everything throughly and my homeboi checked behind me. Under throttle everything is fine,but at idle the misfires start. I recently done a tuneup the summer so i wouldnt figure plugs or wires. Could this be a vac leak between the spacer and manifold or plenum? Does have plenty noticable pull on take off ever with these issues
  2. #2 Re: hv3 install
    GTP Level Member L36 Killer's Avatar
    Jul 2012
    Harrisburg, Pennsylvania, United States
    I would first double check to make sure the plug wires are on the right plugs. It sounds too easy to miss, but I've done it myself Checking for a vacuum leak with some carb cleaner is a good idea too. Also, check the plug to the evap purge valve
    "SHELLY" GRAND PRIX GT 02. SLP HEADERS & EXHAUST, K&N CAI, BMR REAR SUSPENSION AND STRUT BRACES, 180 T-STAT, AGX STRUTS, EIBACH SPRINGS, OVERKILL PCM, YELLA TERRA 1.7 ROCKERS, GT1 CAM, SEXMAN PORTED & POLISHED HEADS, STAGE 2 PORTED TB
  3. #3 Re: hv3 install
    Jul 2011
    Baltimore, MD
    Checked all plugs. Guess i gotta take it all apart and start over. Blahhh
  4. #4 Re: hv3 install
    Omaha, NE
    I would say its a vac leak.
    My HV3 was sluggish from a dig, and pulled hard up top.
  5. #5 Re: hv3 install
    Pennsylvania
    With my hv3 when I had the NA car, it was kind of a pain to get the gasket seated right... make sure the bolts are tight... I didnt tighten mine enough and I had a vac leak... then they came looser and I had a huge coolant leak that left me stuck in the rain trying to fix it, lol.
    But yeah definitely check the plug wires, as it was said they're really easy to mix up if you're rushing or not paying close attention.
    There's really nothing you're touching there that should be causing misfires except that, unless you unplugged the injectors from the rail and they're not connected right.
    Sport Edition Kv5 18x8
  6. #6 Re: hv3 install
    Jul 2011
    Baltimore, MD
    Ok, now if i remember correctly when we were putting this back together, he didnt replace the UIM gasket because he could not
    figure out how to make it work. I told him that im sure it still needs a gasket, but he insisted it would be ok, because of the
    RTV between the HV spacer and the the manifold...could this be it?
  7. #7 Re: hv3 install
    Pennsylvania
    yeah... you dont just rtv it, lol. The gasket only goes on one way, just fit it to the shape of the manifold... and you gotta use the one that came with it, the stock one has a clip that wont fit anymore.
  8. #8 Re: hv3 install
    Jul 2011
    Baltimore, MD
    i grabbed it used here off the forums, so i guess i would have to get one through zzp?
  9. #9 Re: hv3 install
    Omaha, NE
    Any parts store should stock them. They call them "plenum gaskets".
  10. #10 Re: hv3 install
    Jul 2011
    Baltimore, MD
    yea i know i was at autozone this morning and the guy at the counter didnt know what i was talking about.
    kept trying to give me the lower intake when i told him upper. then tried to sell the entire plenum to me...
    i just walked out.
  11. #11 Re: hv3 install
    Pennsylvania
    If you buy a stock one, though, I think you'll have to cut the clip off.. the factory one has a clip that attaches it to the intake runners, which wont work with the hv3 in there.
  12. #12 Re: hv3 install
    Omaha, NE
    It's been a few years, but I want to say I found a way for the clips to work. I don't recall exactly.
  13. #13 Re: hv3 install
    Dec 2008
    Lawndale, CA
    Go ahead and cut the clips that hold that palstic tube. You don't need either the clips or the tube. Then the gasket will sit flush with the HV3 within the UIM.
  14. #14 Re: hv3 install
    Jul 2011
    Baltimore, MD
    Coo. I'll break it down tomorrow,i've had to work since i put it on. No time to fool wit it. Im not hurting the car by driving it with these codes im runnin am i?
  15. #15 Re: hv3 install
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    Of you have a vacuum leak yes you could hurt the engine cause your engine is sucking in in metered air. You coukd be driving really lean.... drive it nicely
  16. #16 Re: hv3 install
    Jul 2011
    Baltimore, MD
    Damnit, well i'll get after it tomorrow morning. I found the gasket on autozone website, the guy was just being lazy when i went yesterday
    morning. Should i razor blade the clips off? Trying to avoid breaking the new gasket, by modifying it to the insert. Thanx for the help
    so far folks.
  17. #17 Re: hv3 install
    Jul 2011
    Baltimore, MD
    so far folks.
  18. #18 Re: hv3 install
    Dec 2008
    Lawndale, CA
    Best pic I could find for now. You want to cut the two clips holding the clear plastic tube. I used a pair of wire cutters to trim them. You just need to trim them enough to where the gasket sits flush with the HV3. You also don't need that plastic tube.
  19. #19 Re: hv3 install
    Jul 2012
    pardon the side track but, what IS that plastic tube for?
  20. #20 hv3 install
    Omaha, NE
    It's supposed to help direct air to the PCV.
    Aka it's worthless.
  1. Install a ZZP MPS?
    By slimguns in forum General Tech Discussion
    Last Post: 06-14-2013, 12:34 PM
  2. hv3 install
    By vailskier3 in forum How To Write-Ups/Tech Tips
    Last Post: 08-12-2011, 09:12 PM
  3. Help with HID Install
    By trenaro in forum Visual/Body Modifications
    Last Post: 03-23-2011, 12:04 PM
  4. please help!!! cai install
    By BIGTMANE in forum General Tech Discussion
    Last Post: 06-05-2009, 05:27 PM
  5. need help with LOC install!!!
    By riceburner in forum Audio, Security & Visual Electronics
    Last Post: 11-09-2008, 04:00 PM
