Thread: check engine light help - p0102 and p1655
Results 1 to 10 of 10
  1. #1 check engine light help - p0102 and p1655
    SE Level Member JB122894's Avatar
    May 2012
    Illinois
    I recently got a check engine light on my 97 gtp. I installed a FWI a month or so ago, and I don't know if that contributed to the problem. I've cleaned the MAF, changed my oil because it was low. There is also a recent sound like rattling coming from my exhaust...could be unrelated or related I'm not sure. Could a rear o2 cause these two codes, and any help is much appreciated.
    1997 Grand Prix GTP
  2. #2 Re: check engine light help - p0102 and p1655
    SE Level Member jkroll17's Avatar
    Mar 2013
    Eastpointe MI
    What are your symptoms? The rear o2 sensor will throw a code called 02 heater circuit low or no signal, but it will not effect the performance of the car
    2000 gt coupe I'm on a first name basis with tow truck drivers
    New crate 3800 v6 N/A, Borla exhaust, crappy K&N cold air intake. The rust makes my car lighter and faster.
    >> http://www.grandprixforums.net/showthread.php?t=83513 <<
  3. #3 Re: check engine light help - p0102 and p1655
    Mar 2013
    Eastpointe MI
    As for the po102 refer to http://www.automotiveforums.com/t707...ith_po102.html
    theres some great info in there
  4. #4 Re: check engine light help - p0102 and p1655
    May 2012
    Illinois
    i had no problems until the day of, and the symtoms were also i did have a o2 heater circuit lower coming on once a week. i kept turning it off cuz i thought it was from the headers, and ok ill check it out thanks
    1997 Grand Prix GTP
  5. #5 Re: check engine light help - p0102 and p1655
    Mar 2013
    Eastpointe MI
    Quote Originally Posted by JB122894 View Post
    NP. o2 heater circuit low or no signal is nothing though, just a nuisance code basically. It just means that your useless o2 sensor needs to be replaced or it will keep complaining. id recommend just putting a simulator in in place of it and deleting that restrictive u-bend that it is threaded into. might as well seeing as you have headers. the headers would be wayyy more effective if you got rid of that u-bend
  6. #6 Re: check engine light help - p0102 and p1655
    Mar 2013
    Eastpointe MI
    The other code is for a evap purge solenoid which monitors pressure in your gas tank if i am correct... meaning that it is stuck open or closed and not doing its job properly. I dont believe it effects your drive ability, its more of a safety issue. but if someone else could pipe in on that to be sure...
  7. #7 Re: check engine light help - p0102 and p1655
    Banned
    Oct 2013
    Moorhead, MN
    Doesn't the rear o2 sensor help regulate MPG? As in fuel saturation, etc?
    My mom's Blazer needs an exhaust o2 sensor and is running like sh*t.
  8. #8 Re: check engine light help - p0102 and p1655
    Mar 2013
    Eastpointe MI
    Quote Originally Posted by Thompsju View Post
    nah, its mostly there to tell if your cats clogged or not. it depends on what car though and which o2 it is. the older gp's its nothing. at the shop i work at we actually weld them to the outside of the pipe so the code doesnt come up anymore lol and if you delete the code enough itll just stop throwing it up.
  9. #9 Re: check engine light help - p0102 and p1655
    Mar 2013
    Eastpointe MI
    my rear o2 is bad right now too and it's been that way for about a month. no change in gas mileage or drive ability
  10. #10 Re: check engine light help - p0102 and p1655
    May 2012
    Illinois
    thanks for all the help. i took a look at it today and it was the rear o2 that was wearing against the one of the rubber rings that holds the exhaust up. There is supposedly a pink wire than runs through the wire that was rubbing, that also runs to the maf. My fuse number 21 was blown and i replaced it. both codes have gone away and ill replace that o2.
    1997 Grand Prix GTP
  1. Check engine light comes on then goes off
    By BeezyPlatt in forum 5.3L V8 (LS4)
    Last Post: 12-20-2012, 01:27 PM
  2. check engine light
    By Grandprixgt001 in forum General Grand Prix Discussion
    Last Post: 12-12-2012, 02:59 PM
  3. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  4. check engine light and lose wire in engine bay
    By Fcukit33 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2011, 05:29 AM
  5. check engine light
    By unclefester in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-18-2011, 09:33 PM
