Thread: Check engine light comes on then goes off
Results 1 to 6 of 6
  1. #1 Check engine light comes on then goes off
    Apr 2012
    Louisiana
    i have a 06 grand prix gxp and bout 2 months ago my car started sputting/missing when i accelerate. i figured that maybe i bought some bad gas or one of my spark plugs fouled out. when this happened my check engine light came on so i put some gas treatment in & it then later went off. i then changed my spark plugs a few days later. the other day when i filled up my gas tank it did it again immediately so i put more gas treatment then the problem stopped. later on that evening my car started doing it again and the check engine light came on. I put a scan tool on it and the code P3449 came up which read "Cylinder 7 Deactivation/Intake Valve Control Circuit/Open". Has this happened to anyone else before? if so what can i do to resolve it?
  2. #2 car sputs/misses when accelerating
    Apr 2012
    Louisiana
  3. #3 Re: car sputs/misses when accelerating
    I stole this from a truck forum. But it has the info you want.
    2007 GMC Truck Sierra - 2WD | Sierra, Silverado (VIN C/K) Service Manual | Document ID: 1741272
    DTC P3400
    Diagnostic Instructions
    • Perform the Diagnostic System Check - Vehicle prior to using this diagnostic procedure.
    • Review Strategy Based Diagnosis for an overview of the diagnostic approach.
    • Diagnostic Procedure Instructions provide an overview of each diagnostic category.
    DTC Descriptor
    DTC P3400: [COLOR=blue !important][COLOR=blue !important]Cylinder[/COLOR][/COLOR] Deactivation System Performance
    Diagnostic Fault Information
    Circuit
    Short to Ground
    Open/High Resistance
    Short to Voltage
    Signal Performance
    Ignition 1 Voltage
    P0102, P0443, P3401, P3425, P3441, P3449
    P3400, P3401, P3425, P3441, P3449
    P3400
    Cylinder 1 Deactivation Solenoid Control Circuit 1
    P0300, P3401
    P0300, P3400, P3401
    P0300, P3401
    P3400
    Cylinder 4 Deactivation Solenoid Control Circuit 2
    P0300, P3425
    P0300, P3400, P3425
    P0300, P3425
    P3400
    Cylinder 6 Deactivation Solenoid Control Circuit 3
    P0300, P3441
    P0300, P3400, P3441
    P0300, P3441
    P3400
    Cylinder 7 Deactivation Solenoid Control Circuit 4
    P0300, P3449
    P0300, P3400, P3449
    P0300, P3449
    P3400
    Circuit/System Description
    The cylinder deactivation system is used to deactivate 4 cylinders of the engine under light load driving conditions. The engine control module (ECM) commands the cylinder deactivation solenoids ON to deactivate [COLOR=blue !important][COLOR=blue !important]engine [COLOR=blue !important]cylinders[/COLOR][/COLOR][/COLOR] 1, 7, 6, and 4, switching to 4 cylinders or V4 mode. The cylinder deactivation solenoids controls the oil flow to the appropriate valve lifters. The engine operates on 8 cylinders or V8 mode, during engine starting, engine idling, and medium to heavy [COLOR=blue !important][COLOR=blue !important]throttle[/COLOR][/COLOR] conditions.
    Ignition voltage is supplied directly to the 4 cylinder deactivation solenoids. The engine control module (ECM) controls the 4 cylinder deactivation solenoids by grounding the control circuit with a solid state device called a driver.
    The Cylinder Deactivation System Performance diagnostic is a test of the internal mechanical condition of the engine, during operation in V4 mode. The engine control module (ECM) determines the internal mechanical condition of the engine through the actual measured values of the mass airflow (MAF) sensor, the intake manifold absolute pressure (MAP) sensor, and the throttle position sensor. The actual measured values of the 3 sensors are then compared to the calculated values for V4 mode, stored in the ECM. If the measured values are incorrect for V4 mode, the ECM will set DTC P3400, and will return to V8 mode operation.
    Conditions for Running the DTC
    • DTCs P0102, P0103, P0107, P0108, P0112, P0113, P0117, P0119, P0335, and P0336 are not set.
    • The [COLOR=blue !important][COLOR=blue !important]engine [COLOR=blue !important]speed[/COLOR][/COLOR][/COLOR] is between 450-6,400 RPM.
    • The IAT Sensor parameter is between -7 and +125°C (+19 and +257°F).
    • The ECT Sensor parameter is between 70- 125°C (158-257°F).
    • Time in V8 mode is greater than 2 seconds.
    • Time in V4 mode is greater than 2 seconds.
    • This DTC runs continuously within the enabling conditions.
    Conditions for Setting the DTC
    • The control module detects that the actual measured values from the MAF sensor, MAP sensor, and TP sensor, is not within the range of the calculated values for V4 mode.
    • The above condition is met for greater than 100 milliseconds.
    Action Taken When the DTC Sets
    • DTC P3400 is a Type B DTC.
    • The engine will return to V8 mode.
    Conditions for Clearing the DTC
    Diagnostic Aids
    • This DTC will not set during engine idling conditions. The vehicle will need to be driven for the DTC to set.
    • The valve lifter oil manifold solenoids are assigned to the following engine cylinders:
    - Solenoid #1 = Cylinder #1
    - Solenoid #2 = Cylinder #4
    - Solenoid #3 = Cylinder #6
    - Solenoid #4 = Cylinder #7
    Reference Information
    Schematic Reference
    Engine Controls Schematics
    Connector End View Reference
    • Engine Control Module Connector End Views
    • Engine Controls Connector End Views
    • Electrical Center Identification Views
    Description and Operation
    Cylinder Deactivation (Active Fuel Management) System Description
    Electrical Information Reference
    • Circuit Testing
    • Connector Repairs
    • Testing for Intermittent Conditions and Poor Connections
    • Wiring Repairs
    DTC Type Reference
    Powertrain Diagnostic [COLOR=blue !important][COLOR=blue !important]Trouble [COLOR=blue !important]Code[/COLOR][/COLOR][/COLOR] (DTC) Type Definitions
    Scan Tool Reference
    • Scan Tool Data List
    • Scan Tool Output Controls
    • Scan Tool Data Definitions
    Special Tools Required
    EN-46999 Displacement On Demand Tester
    Circuit/System Verification
    1. Note: The [COLOR=blue !important][COLOR=blue !important]engine [COLOR=blue !important]oil[/COLOR][/COLOR][/COLOR] level and the oil pressure are critical to the correct operation of the Cylinder Deactivation System. Verify that the engine has the correct oil level and the correct oil pressure before continuing with this diagnostic. Refer to Oil Pressure Diagnosis and Testing. Inspect the Valve Lifter Oil Filter for a restriction or blockage. Refer to Valve Lifter Oil Filter Replacement.
    <LI type=1>Ignition ON, observe the scan tool DTC information. Verify that DTC P0201-P0208, P0351-P0358, P3401, P3425, P3441, or P3449 is not set.
    ⇒If a DTC is set, refer to Diagnostic Trouble Code (DTC) List - Vehicle for further diagnosis.
    <LI type=1>Engine idling at the normal operating temperature. Verify there is no abnormal [COLOR=blue !important][COLOR=blue !important]engine [COLOR=blue !important]noise[/COLOR][/COLOR][/COLOR].
    ⇒If there is an abnormal engine noise, refer to Symptoms - Engine Mechanical for further diagnosis.
    <LI type=1>Perform the Cylinder Deactivation (Active Fuel Management) System Compression Test. The Cylinder Deactivation System should pass the compression test.
    2. Operate the vehicle within the Conditions for Running the DTC to verify the DTC does not reset. You may also operate the vehicle within the conditions that you observed from the Freeze Frame/Failure Records data.
    Circuit/System Testing
    1. <LI type=1>Ignition OFF, remove the valve lifter oil manifold assembly ignition fuse from the underhood fuse block. Note: Probe each terminal at the underhood fuse block with a test lamp connected to ground to determine what terminal to connect the DMM. The test lamp should not illuminate on the circuit that needs to be tested.
    <LI type=1>Connect a DMM between the ignition circuit fuse terminal going to the valve lifter oil manifold assembly and the ECM housing. <LI type=1>Ignition ON, command each Cylinder 1, 4, 6, and 7 Deactivation solenoid ON and OFF with the scan tool. Verify the resistance of each solenoid is between 11-18 Ω with the solenoid commanded ON.
    ⇒If greater than the specified range for all cylinder deactivation solenoids, test the ignition circuit for an open/high resistance.
    ⇒If greater than the specified range for one or more but not all cylinder deactivation solenoids, test both the control circuit and ignition circuit for an open/high resistance or an open/high resistance in the cylinder deactivation solenoid. If the circuits and solenoid test normal replace the ECM.
    2. If all circuits and components test normal, refer to Cylinder Deactivation (Active Fuel Management) Valve Lifter Oil Manifold Diagnosis and Testing for further mechanical diagnosis of valve lifter oil manifold assembly.
    Component Testing
    Static Test
    1. <LI type=1>Ignition OFF, disconnect the harness connector at the valve lifter oil manifold assembly. <LI type=1>Connect the harness that is labeled resistance from the displacement on demand (DOD) tester to the valve lifter oil manifold connector. <LI type=1>Connect the power leads from the DOD tester to B+ and ground. Test for 11-18 Ω on each valve lifter oil manifold solenoid.
    ⇒If not within the specified range for each solenoid, replace the valve lifter oil manifold assembly.
    2. Test for infinite resistance between each valve lifter oil manifold circuit terminal listed and the valve lifter oil manifold housing.
    ⇒If less than infinite resistance, replace the valve lifter oil manifold assembly.
    Dynamic Test
    1. <LI type=1>Ignition OFF, disconnect the harness connector at the valve lifter oil manifold assembly. <LI type=1>Connect the cable that is labeled power from the displacement on demand DOD tester to the connector. <LI type=1>Connect the power leads from the DOD tester to B+ and ground.
    2. Command each valve lifter oil manifold solenoid ON and OFF using the DOD tester. You should be able to hear each solenoid turn ON and OFF.
    ⇒If the function does not perform as specified, replace the valve lifter oil manifold assembly.
    Repair Instructions
    Perform the Diagnostic Repair Verification after completing the diagnostic procedure.
    • Valve Lifter Oil Manifold Replacement
    • Control Module References for ECM replacement, setup, and programming
    © 2010 General Motors. All rights reserved.
  4. #4 Re: car sputs/misses when accelerating
    Merged
  5. #5 Re: Check engine light comes on then goes off
    Yoga city
    Could be the common ground on the block issue, ive solved alot of codes i had by just going through cleaing/retourqing all ground connections. along with dielectric grease on connectors.
  6. #6 Re: Check engine light comes on then goes off
    Dec 2012
    St. Paul
    Quote Originally Posted by BeezyPlatt View Post
    This happened to me too just recently. I drove about 2.5 hours on an interstate and once i reached home and in town driving, my check engine light came on and acceleration was rough and didn't idle real nice. i put the code reader on it right away and said "cylinder 7 misfire" {i had some bad battery problems earlier, so maybe ignition wasnt very good and it go thrown off once?} who knows. i simply erased the code and started and drove just fine and the light has yet to return. sometimes the system gets wet or something so little goes wrong and the car throws out a code right away.
  1. Check engine light
    By 0GTP4 in forum General Tech Discussion
    Last Post: 02-11-2012, 11:24 AM
  2. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  3. check engine light and lose wire in engine bay
    By Fcukit33 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2011, 05:29 AM
  4. Check Engine Light
    By lemmy33 in forum General Tech Discussion
    Last Post: 11-03-2011, 04:10 PM
  5. check engine light
    By kiljoy06 in forum General Tech Discussion
    Last Post: 01-11-2009, 07:27 AM
