Thread: another engine light -_-
Results 1 to 20 of 28
  1. #1 another engine light -_-
    Apr 2013
    Michigan
    After driving on the freeway for awhile earlier with no problems, I got back in my car to get back on and head home when the service engine light came on for the first time in a few months. The way the car ran was fine, I went and had it scanned and the code is P0305 and they basically gave me three things that fixed it before, changing the coil packs, ignition coils, or ignition module. Im not very mechanical lol but are these things that could be done without taking it to a shop? any other ideas what it could be? I read it could be the crank sensor too which kind of makes sense to me because the car has randomly shut off on me while driving but it only happened once and it was awhile ago, any ideas?
  2. #2 Re: another engine light -_-
    Apr 2013
    Michigan
    lol
  3. #3 Re: another engine light -_-
    When was the last tune up?
  4. #4 Re: another engine light -_-
    Apr 2013
    Michigan
    when i bought it in january, i know the wires/plugs were changed for sure but he never said anything about the coils
  5. #5 Re: another engine light -_-
    Pull the plug and look at it and check the wire over too
  6. #6 Re: another engine light -_-
    Apr 2013
    Michigan
    when i get some time i will, but is it fine to drive for now? it drove home fine i just dont wanna risk the car shutting off on me while im gone
  7. #7 Re: another engine light -_-
    SE Level Member jkroll17's Avatar
    Mar 2013
    Eastpointe MI
    Where did you have it scanned? if it was somewhere like autozone where they scan it for free its not that great of info. if you dont mind spending the money its better to take it to a shop to have it diagnosed on a real scan tool where they can see where its missfiring and how often. if it is two cylinders on the same coil pack obviously its the coil pack, if its just one cylinder you probably just have a bad plug or something. i know from working in a shop that often mechanics put in spark plugs with air tools out of laziness and that could lead to a cracked plug
    2000 gt coupe I'm on a first name basis with tow truck drivers
    New crate 3800 v6 N/A, Borla exhaust, crappy K&N cold air intake. The rust makes my car lighter and faster.
    >> http://www.grandprixforums.net/showthread.php?t=83513 <<
  8. #8 Re: another engine light -_-
    Apr 2013
    Michigan
    yeah i had it done at an oreilleys, and ill get around to that when i have time but that wont be til monday, until then am i fine driving it as normal?
  9. #9 Re: another engine light -_-
    Mar 2013
    Eastpointe MI
    oh for sure. if the misfire isnt noticeable under regular driving conditions, you will be perfectly fine. you may notice small mpg differences but it is completely drivable unless it is shaking your fillings out lol
  10. #10 Re: another engine light -_-
    Apr 2013
    Michigan
    alright cool
  11. #11 Re: another engine light -_-
    Banned
    Oct 2013
    Moorhead, MN
    Okay, a light came on but... What are the symptoms?
  12. #12 Re: another engine light -_-
    Apr 2013
    Michigan
    there arent any that i can notice, the lights not on now and i restarted the car a few times it hasnt come back yet
  13. #13 Re: another engine light -_-
    Mar 2013
    Eastpointe MI
    If the light is gone you will be fine. The pcm runs self checks on the cars systems and when multiple missfires are detected at once will throw a code. Each time the car is started it will run the test again and after so many tests without multiple missfires detected the pcm will get rid of the code. Cars are not 100% efficient and missfire every once in a while. It just happened that multiple missfires happened at once. I would not bother checking anything unless the engine light comes back on. If it does, then proceed to do what was recommended earlier
  14. #14 Re: another engine light -_-
    Mar 2013
    Eastpointe MI
    now if you want to know for sure, while getting on the freeway just open up your throttle allllllll the way. Try it a few times.And if your engine light comes on or flashes then you do have a consistent missfire. if the light doesnt come on from that, forget about it. another way to check that isnt as reliable especially if youre not looking at a missfire counter on a scanner is by brake torquing at lower rpms sometimes your car will missfire. (such as 1500-2000 rpm's) just dont go crazy on the brake torquing
  15. #15 Re: another engine light -_-
    Apr 2013
    Michigan
    lol thanks, hopefully it just stays off ive still got other **** to fix lol
  16. #16 Re: another engine light -_-
    Mar 2013
    Eastpointe MI
    Amen lol I feel your pain
  17. #17 Re: another engine light -_-
    Apr 2013
    Michigan
    this doesnt really have anything to do with this but how do i am down my headlights? i put my hids back in and theyre not aimed totally at the ground and theyre already 10ks so i cant see much already lol
  18. #18 Re: another engine light -_-
    Banned
    Oct 2013
    Moorhead, MN
    Well the mounting is already awful for these.
  19. #19 Re: another engine light -_-
    Mar 2013
    Eastpointe MI
    Theres screws on top of the headlight bucket that adjust the beam.
  20. #20 Re: another engine light -_-
    Apr 2013
    Michigan
    i see lol i was thinking of switching to like 6ks instead so there not so blue
  1. Flashing Engine Light/Engine Light
    By GP38 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-29-2012, 10:15 PM
  2. Replies: 1
    Last Post: 02-14-2012, 05:03 PM
  3. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  4. Service Engine light flashes... engine shakes...hardly any power at all
    By bigbluegtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2010, 07:10 PM
  5. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
