As much as I take care of my motor these people had the nerve to fail my SMOG test yesterday. I have ZZP Item #: ZZ-TOG-CA25 aluminized downpipe with cat with 2.5" exit, but apparently my CAT is bad now and non C.A.R.B. certified. Now ive had this CAT for like 7yrs and ive always passed emissions bc it was legal but now they claim its not and is considered moddified and tampered with. I know just back in 09' the California association resource board was revised which probably for some reason then excluded my CAT. Now this was in 09', mind you I got my smog in 11' (smog required every 2yrs out here) with this very same CAT and passed visually and the emissions.
Emissions results:
15 MPH: HC PPM- Max 51 actual 53 NO PPM- Max 419 Actual 659 FAILED
25 MPH: HC PPM- Max 35 Actual 38 NO PPM- Max 706 Actual 577
Now the readings tell me that something may be wrong or clogged (mind you this was yesterday morning around 830am 55* outside on the chilly side and my car could'nt have been to full operating temp ( my fault) but im down with replacing anything needed to improve my cars efficiency.
Now I am dissappointed that my CAT was legal for 7yrs and now all of the sudden my numbers dont match and its not legal. Thats bull and they still charged me $40 after I failed. LOL they offered to change my CAT ($400 from their parts source) my O2 sensor, $200 for labor and ill get a free re-smog test.
I laughed so hard....Im getting this Cherry Bomb 656008 California OBD-II Universal Catalytic Converter for CARB Emission Vehicles for $186, Bosch O2 sensor for $28 and installing it myself. Then go to the smog shop 2 blocks away and get it done for $28 which is cheaper.
Totally saving a bunch of money. I love it when I go into a mechanic repair shop and talk to a mechanic but they have no idea that they're talking to a mechanic. FUNNY.........
Mind you less than a year ago at the shop I put a presssure gauge in the upstream O2 sensor port and back pressure read about .5-1.0 PSI which is totally fine and I just had my scanner on my car 2wks ago and my O2 sensors was between .1-.9volts very steady and fluctuating as necessary between the two O2 sensors.
At the end of the day my NO was well over the Max so ima just change the CAT(been having some hesitation anyway at low and high RPMs), knock out the O2 sensor since its very vital and only $30, and probaly a bottle of Techron with a nice long drive to knock off some carbon build up(fuel filter should be fine, changed it bout 5 months ago but only put less than 5,000 miles on the car since then). Everything else is literally new or fresh no hopefully these few maintenence solutions will do the trick.
Long story but the moral is to do your homework and to know about your car because these mechanics will rip you off(some will). Study emissions too, may help you on your next emission test or should i say save you a lil money......
