Thread: Swapping Headlight's Question
Results 1 to 5 of 5
  1. #1 Swapping Headlight's Question
    Jun 2013
    Canada
    Recently my headlight was like fogged up or something like it was covered up and so my dad and I ended up cleaning it up with something we got from NAPA and well I still find the headlights are kinda crappy! I found on usedregina a headlight assembly for a grand prix 2006 and was wondering if it would be the same for my 99 grand prix GT
  2. #2 Re: Swapping Headlight's Question
    SE Level Member Thinksun's Avatar
    Sep 2012
    GTP Ontario
    I sanded my headlights downs and sprayed a catalyzed clear coat (only clear with UV stabilizers). They looked brand new and crystal clear until I looked at them from an angle. The plastic had grazing cracks deep into plastic-I tried them anyway and they were junk. I bought a new set off ebay from headlight factory in Michigan for $88 a set and they work excellent. New lights are generally the only real fix.
    1997 GTP .
  3. #3 Re: Swapping Headlight's Question
    GTP Level Member tms8582's Avatar
    Washington Michigan
    Most people I know with the 97-03 GP's use the original brackets and get aftermarket headlights. I've tried restoring the factory lenses and they never look clear. When you buy the new headlight assembly it comes with the brackets but they are flimsy and personally I just reuse the factory ones because they are much stronger. However sometimes the old adjusting screws get fused and wont adjust... 1997-2003 Pontiac Grand Prix Headlight Assembly - Pair (Both Driver and Passenger Sides) 98 99 00 01 02 (with Side Marker Light) - AutoLightsBulbs.com
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  4. #4 Re: Swapping Headlight's Question
    97-03 are one type of headlight that will work with your car 04-08 will not.
  5. #5 Re: Swapping Headlight's Question
    Jun 2013
    Canada
    Before
    After
  1. Question about swapping from digital climate control to manual
    By Bjorn20 in forum General Tech Discussion
    Last Post: 12-22-2011, 12:33 AM
  2. HID headlight Question..
    By ddrum in forum Visual/Body Modifications
    Last Post: 06-09-2010, 04:40 PM
  3. engine swapping question
    By PrixGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2009, 10:43 PM
  4. Replies: 0
    Last Post: 09-11-2009, 08:33 AM
  5. headlight question
    By NewPrixOwner666 in forum Visual/Body Modifications
    Last Post: 06-16-2009, 10:02 PM
