Thread: Pictures of removing subframe with engine and transmission using cherry picker
Results 1 to 8 of 8
  1. #1 Pictures of removing subframe with engine and transmission using cherry picker
    Aug 2012
    MI
    Does anyone have pictures/video of removing a subframe with engine and transmission still attached using cherry picker in a 2000 Grand Prix? I have a 2 stall garage with a driveway that has a little slope to it and I was wondering if this would be possible with my garage door. I cant seem to find any pictures for doing this on a Grand Prix.
  2. #2 Re: Pictures of removing subframe with engine and transmission using cherry picker
    Look for the how to remove a transmission thread.
    I think Billboost has picture's on how its done, but I can't be 100% on that.
  3. #3 Re: Pictures of removing subframe with engine and transmission using cherry picker
    I did it in my garage with just jacks and Jack stands
  4. #4 Re: Pictures of removing subframe with engine and transmission using cherry picker
    You can't pull the subframe out the top with a cherry picker, you could lift the car..but then it needs to be supported and have the picker removed to move the subframe.
    See the how to engine, transmission or drivetrain write ups if you want the on your back in a garage without a lift methods that I use.
  5. #5 Re: Pictures of removing subframe with engine and transmission using cherry picker
    Aug 2012
    MI
    I was just looking for pictures of how people attached the cherry picker to the car/bumper to lift the body off of the subframe with engine and transmission/struts still attached to the subframe. It seems like I would run out of room in a 2 stall garage or the cherry picker would hit the garage door lifting the body of the car. Thanks!
  6. #6 Re: Pictures of removing subframe with engine and transmission using cherry picker
    Uhhhhh I would move things far enough out of the way so you don't hit the door. My garage ceiling is only about 8-9 feet and this is why I pull things out the top. However you could attach to the front bumper and with a short chain.. I'd assume the roof/hood would be higher than the picker at that point.
    Problem I see is you have to put your subframe onto blocks or something to keep it from resting on the engine hoist legs if you have one that goes under the car like most.
  7. #7 Re: Pictures of removing subframe with engine and transmission using cherry picker
    Aug 2012
    MI
    I also wanted to say thanks Bill! I used you write-up to remove the engine from the car out the top. I am looking for a replacement motor from a JY now. Old motor spun a rod bearing.....
    I am just curious to see pictures how people lift the body off of the subframe using a cherry picker and then slide out the subframe.
  8. #8 Re: Pictures of removing subframe with engine and transmission using cherry picker
    Look up Sven Sexman and his Anna Nicole build. He has the car on a lift though. I personally go out the top because of how high I'd have to jack the body, and needing to have it aligned after pulling the subframe.
  1. Removing Engine and Transmission together
    By topswap in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-03-2016, 09:32 AM
  2. removing items to clean up the engine bay?
    By z3r0 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-01-2011, 11:32 AM
  3. Subframe or engine cradle bolts HELP
    By ryan12473 in forum Brakes/Suspension/Chassis
    Last Post: 05-24-2011, 06:17 AM
  4. Best way to remove engine and trans ...subframe ?
    By girthman49 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-17-2011, 04:30 PM
  5. Cherry Picker Questions??
    By Iron Indian in forum Off Topic Discussion
    Last Post: 01-28-2008, 08:41 PM
