Thread: Question
Results 1 to 20 of 22
  1. #1 Question
    GT Level Member tyv193's Avatar
    Jul 2010
    Central Ny
    I used be on this site a lot more but havnt been on in prolly a year. Looking to add se parts to my car. My question is. If I got headers what should I get? How much would mechanic charge to install? Also cam or rockers? What would the cost of installation be on that?
    Thanks
    2002 GTP
  2. #2 Re: Question
    Headers you can get cheap ones but a mechanic is gonna charge you probably 7-8 hours to do it if they will even do it. Cam install will probably be about the same. Rockers like 3-4 hours. If you do them yourself you'll save a ton of money.
  3. #3 Re: Question
    Jul 2010
    Central Ny
    I've never done anything like it so I feel like I wouldn't be Able to. I don't have access to a lift either..
    2002 GTP
  4. #4 Re: Question
    no need for a lift. I do all my own work with a jack and some jack stands in my garage at home. Rockers are super easy anyone could do them. Headers are a little more involved and a cam isn't something that should be done without a knowledge of the inner workings of the motor.
  5. #5 Re: Question
    Jul 2010
    Central Ny
    Is there a thread here that is a DIY for rockers or headers?
    2002 GTP
  6. #6 Re: Question
    I know there is a header one. Billboost37 started it. I'm not sure about rockers but on those the hardest part is getting the valve covers off.
  7. #7 Re: Question
    Jul 2010
    Central Ny
    Would they come with any directions? What ones would you recommend ?
    Would I need to add any other parts to run them properly
    Tune?
    2002 GTP
  8. #8 Re: Question
    I ran zzp modded 1.9 rockers with no problems for 30K miles. You wouldn't need any other parts or a tune but you'll benefit from it.
  9. #9 Re: Question
    Jul 2010
    Central Ny
    Ok thanks! Would I gain maybe 10 hp if I add em without a tune?
    Thanks for the help I appreciate it
    2002 GTP
  10. #10 Re: Question
    You'll notice some top end but I didn't notice much.
  11. #11 Re: Question
    Jul 2010
    Central Ny
    Is it worth it then?
    2002 GTP
  12. #12 Re: Question
    If you can get a set kinda cheap it's worth it. It killed a lot of my KR
  13. #13 Re: Question
    Jul 2010
    Central Ny
    Headers and rockers would I notice anything?
    I would prolly have to get a tune. Idk where I would tho. I'm assuming a can tune wouldn't help all that much. I'm in CNY area
    2002 GTP
  14. #14 Re: Question
    Headers and rockers probably won't add any noticeable power, but you would be able to run a smaller pulley, and that is where you will notice an increase in power.
  15. #15 Re: Question
    Jul 2010
    Central Ny
    Quote Originally Posted by slick2500 View Post
    Run smaller without a tune? Like a 3.4 or 3.5?
    2002 GTP
  16. #16 Re: Question
    Jul 2010
    Central Ny
    What about 1.84 YT rockers and a down pipe. Would down pipe be easier than headers and still be able to drop a pulley?
    Thanks
    2002 GTP
  17. #17 Re: Question
    Headers and rockers could easily run a 3.4
  18. #18 Re: Question
    Jul 2010
    Central Ny
    What about just rockers? Or rockers and a DP?
    2002 GTP
  19. #19 Re: Question
    Rockers and a dp probably could run a 3.5 but you wouldn't really know unless you we're scanning for kr
  20. #20 Re: Question
    Jul 2010
    Central Ny
    Headers and rockers I'd be safe on 3.4 without scanning?
    2002 GTP
  1. stupid question, dont mind me.(CAI question)
    By Silversurfer Gio in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2012, 10:40 AM
  2. FWI(fender well intake) question. Exhaust(cat) question.
    By DJspinner in forum General Tech Discussion
    Last Post: 01-23-2010, 01:47 AM
  3. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
  4. Question: Supercharger question.....
    By nmaponte in forum General Tech Discussion
    Last Post: 03-12-2009, 01:04 PM
