Hey guys i have a 04 gt with 175000 miles on it and i just acquired a engine from a 96 buick park avenue ultra. Is it feasable to swap this supercharged engine into the 04 car and if so what is the best way to build it?
It would be easier with a gen v sc
The motor itself will swap right in for the most part. You will need a TB adapter though, since you will need to keep your TB.
I would just do a top swap on your car though. You'll make more power.
How should i build it to keep it reliable? Pulley size, injectors, cam, intercooler, should i change heads? thanks for info
With a top swap, you will have to change the heads.
I would either cam it, or intercool it, depending on your future goals.
