Quote Originally Posted by CyxRyan View Post
Well I pulled off both front tires to check the sensors and they seem to be fine. I called Bel Tire and they want 70 just to read my car but I can get a $20 coupon so pretty much $50.
If you are checking for play on a wheel bearing try rocking the wheels with the tires on. Without the tires on, you may not have enough leverage. At least the three I have replaced, after pulling from the car, there was not any noticeable play. IMHO, if you can see play at the bearing without the leverage of tires, then you are in a dangerous situation.
