Thread: ABS Service, Traction Control Service & variable effort steering.
Results 1 to 20 of 31
  1. #1 ABS Service, Traction Control Service & variable effort steering.
    Apr 2013
    White Lake
    So today when I started my car "ABS Service, Traction Control Service & Variable Effort Steering." I press the reset button to clean them but every time I start my car all 3 pop up again. Yesterday I put a new gas cam on because "check gas cap" has been popping up the past week. Recently I put all new brakes/rotors on my car and now this... If anyone has had this and has fixed the problem please let me know, thanks.
  2. #2 Re: ABS Service, Traction Control Service & variable effort steering.
    get it scanned and find out which wheel bearing is bad.
  3. #3 Re: ABS Service, Traction Control Service & variable effort steering.
    Apr 2013
    White Lake
    What kind of scanner would do this? Because I tried using a scanner that shows codes when check engine light is on but nothing came up?
  4. #4 Re: ABS Service, Traction Control Service & variable effort steering.
    you would need to go to a garage and have the abs scanned.
    or you can also jack each wheel up grab the tire at the top and push and pull firmly, if you feel the whole wheel move the hub is worn out, also check the plugs are clean, and on, and the wires to the plugs are intact.
    if you dont find anything wrong, then go have it scanned, that way your not tossing money at it.
  5. #5 Re: ABS Service, Traction Control Service & variable effort steering.
    Apr 2013
    White Lake
    Scan for free or do they charge you?
  6. #6 Re: ABS Service, Traction Control Service & variable effort steering.
    most will charge for this scan if they are not doing the repair. could be 20 to 80 dollars, as the scanner they use costs thousands.
    there are cheap abs code readers out there. if you buy one make sure it supports your car.
  7. #7 Re: ABS Service, Traction Control Service & variable effort steering.
    I have one that reads abs codes got it for $80 off Amazon
  8. #8 Re: ABS Service, Traction Control Service & variable effort steering.
    Apr 2013
    White Lake
    Well I pulled off both front tires to check the sensors and they seem to be fine. I called Bel Tire and they want 70 just to read my car but I can get a $20 coupon so pretty much $50.
  9. #9 Re: ABS Service, Traction Control Service & variable effort steering.
    order an otc 9450 off amazon and read your own codes for not much more than that.
  10. #10 Re: ABS Service, Traction Control Service & variable effort steering.
    GT Level Member penright's Avatar
    Mar 2013
    United States
    Quote Originally Posted by CyxRyan View Post
    If you are checking for play on a wheel bearing try rocking the wheels with the tires on. Without the tires on, you may not have enough leverage. At least the three I have replaced, after pulling from the car, there was not any noticeable play. IMHO, if you can see play at the bearing without the leverage of tires, then you are in a dangerous situation.
    07 Grand Prix GXP (My Daily Driver and future toy) (120,000+)
    97 Grand Prix GT (Project Car) (178,000+)
    02 Mustang Convertible (Wife's Toy) (75,000+)
    17 Honda Civic (Wife's Daily Driver)
  11. #11 Re: ABS Service, Traction Control Service & variable effort steering.
    May 2013
    Hortonville, WI
    I have had several grand prixs and i have had this exact prob with 2 of them, and both times it was the wire harness coming out of the wheel bearing, where it plugs in nxt to the bearing. you can get a new harness from the plug back towards the car, then you cut the harness and its 2 wires and just splice it back together everything you need comes with it. ( I would recomend using different splices than they send with it). But yes take it in and have it checked first, it will cost about 50 bucks to have them diagnose it, a wheel bearing is about 120-140 bucks aftermarket, and you can also get the harness aftermarket. i got mine from advanced auto parts. Was 48 dollars there and 100 from gm. So have them figure out which one itis first, its cheaper than buying both parts.
  12. #12 Re: ABS Service, Traction Control Service & variable effort steering.
    Jul 2013
    San Bernardino,Ca
    I'm having a similar issue. Had it scanned and it said its the right rear speed sensor. Is it safe to drive with those lights until I can get around to fixing it?
  13. #13 Re: ABS Service, Traction Control Service & variable effort steering.
    Yeah it's prefectly fine. You just won't have abs.
  14. #14 Re: ABS Service, Traction Control Service & variable effort steering.
    Jul 2013
    San Bernardino,Ca
    Well that's not good!!!
  15. #15 Re: ABS Service, Traction Control Service & variable effort steering.
    Won't hurt anything. ABS kinda sucks anyway.
  16. #16 Re: ABS Service, Traction Control Service & variable effort steering.
    Apr 2013
    White Lake
    Funny thing is that my was also the right rear sensor that went bad! When I had it scanned they said they can replace it for $315 out the door and I was like "wtf noo..." and left.... I bought the part from the auto parts store and did it myself. Took me about 20-30 minutes to do and was super easy to replace. Driving it like that won't hurt anything just as soon as you get around to it fix it.!
  17. #17 Re: ABS Service, Traction Control Service & variable effort steering.
    Aug 2013
    Foutnain Valley, California
    I agree it won't hurt anything, but get it fixed before you face slippery roadways. You won't stop as quickly without ABS and you may have issues steering in a skid.
  18. #18 Re: ABS Service, Traction Control Service & variable effort steering.
    Quote Originally Posted by DMAYEADS View Post
    This is not entirely true, ABS is designed to keep the car in control when making sudden stops and in some cases can actually increase your stopping distance. Ever tried to stop on icey roads with abs.
  19. #19 Re: ABS Service, Traction Control Service & variable effort steering.
    i was about to say the same thing, how do you think we all stopped before abs was invented?? personally id rather have all the control, F the computer. they cause more problems then they solved really.
    but you youngsters, its all most of you have ever drove.
  20. #20 Re: ABS Service, Traction Control Service & variable effort steering.
    SE Level Member anemesnyik's Avatar
    Aug 2013
    Greenwood, IN
    I didn't have ABS for about 2 years, I prefer it that way. If it weren't for the obnoxious noise I was getting from the passenger side bearing this time I wouldn't have changed it.
  1. Replies: 5
    Last Post: 02-01-2017, 09:35 PM
  2. Service Variable Effort Steering message
    By wildman124 in forum 04+ Specifics
    Last Post: 08-26-2013, 07:55 PM
  3. Service ABS, traction control, variable steering
    By Lionel in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-31-2011, 08:09 PM
  4. service power steering abs system traction control warning
    By ltr450tremor in forum General Tech Discussion
    Last Post: 05-06-2011, 10:14 PM
