Thread: Loosing coolant.
Results 1 to 6 of 6
  1. #1 Loosing coolant.
    May 2017
    MI Michigan
    Have a 2006 Grand prix base with 146,000 miles on it. I seem to be loosing antifreeze. No leaks anywhere that i can tell. And it's not going out the tailpipe. None mixed with the oil. Anyone have any idea what could be causing this. Car is not overheating and is well. Engine isn't getting overly hot. Can't figure out what the hell is happening.
  2. #2 Re: Loosing coolant.
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    LIMs done?
  3. #3 Re: Loosing coolant.
    If the gasket between the cylinder head and lower intake manifold is black, then it's likely to be the lower intake gaskets.
    Slight chance you have a head gasket but those are the most rare failures.
  4. #4 Re: Loosing coolant.
    May 2016
    MN
    Also check the coolant elbows. Sometimes they can be sneaky little leakers (insert Comey joke here)
  5. #5 Re: Loosing coolant.
    GTP Level Member buickman104's Avatar
    NYC
    Run a pressure test. If you plan on driving cars most of your life then it is a worthy $40 investment.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  6. #6 Re: Loosing coolant.
    May 2017
    MI Michigan
    Thanks for the suggestions , Will check the elbows and perform a pressure test. Not sure if lim was changed, should have checked that before posting question duh, thanks again everyone.
  1. Loosing coolant
    By ajoliver2010 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-30-2017, 12:09 PM
  2. Loosing coolant and oil in my 2001 Grand Prix GTP
    By zguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-29-2015, 09:40 AM
  3. Loosing coolant, engine running hot and rough
    By larsol1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2011, 05:38 PM
  4. Loosing coolant somewhere...please help
    By tgarison in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-16-2011, 10:21 PM
  5. Loosing Gas
    By 04gpking85 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-01-2009, 08:44 PM
