If you're trying to move the car to a better location, turn the key so you can turn the steering wheel, and pop the cable off of the gear selector on top of the tranny. Then move the selector two clicks. That's sets the trans in neutral and you can push the car freely. Once its parked, set the e-brake and block it.
Now might be a good time to swap to solid mounts. The grease filled motor mount can explode and create a royal mess of things. So especially the lower engine mount and trans mount. While the engine is out you can clean up the subframe and hit it with some rust preventer. I bedline sprayed my engine bay while I had my engine out. Might also be a great time to work on the suspension upgrades, namely the front sway bar. Headers would be a great thing to do while its out also. Not much room for that rear manifold once its in the bay.
