Thread: Knock Questions
Results 1 to 7 of 7
  1. #1 Knock Questions
    SE Level Member BigKev2403's Avatar
    Feb 2013
    Cleveland Ohio
    So I had my buddy bring his scanner over to scan for knock, I thought I'd check it after all the plugs, wires, and coils I put in. Under normal conditions knock sat at 0. It came up to about 4 degrees at wide open throttle at around 50-60mph.
    Can you tell me exactly what that means? Is that good? Bad? If its bad what's the best way to improve this?
    Just as a reminder here's what I have. (I will update my sig with this now.)
    180* T-Stat
    PCM
    CAI
    3" DP w/U Bend Delete
    2.5" Magnaflow Cat Back
    I just put in all new coils, AC Delco wires and went with NGK Platinum stock heat range plugs. I did that because I was having the sputter issue and now its cured. Should I go back to my Autolite 104 copper?
    Let me know what you think...
  2. #2 Re: Knock Questions
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    KR is the response from the PCM to cylinder detonation. KR is the measure of the number of degrees of overall ignition timing advance that must be removed from the engine to prevent detonation from continuing, thus protecting the engine from damage.
    Want to reduce KR? Get headers.
    Detonation is what can blow your engine, which is read by KR.
    Read this:
    About Knock Retard (KR) | ZZP News
    http://www.grandprixforums.net/what-...here-1507.html
  3. #3 Re: Knock Questions
    Get them junk platinum plugs out of there.
    Either go with autolite 606 coppers or the ac delco iridiums. Platinum plugs should never be used in a 3800.
  4. #4 Re: Knock Questions
    Feb 2013
    Cleveland Ohio
    Holy hell. Thanks for all the info.
    Are the 606 or Delco stock heat range? Or am I looking for something a range colder
  5. #5 Re: Knock Questions
    Jun 2011
    AL606 and Delco's are stock heat range.
    Our cars, with the blower, love the Copper AL606's, but they need to be replaced every 15,000~ miles.
    Like Cam said, remove the Platinum plugs and put in the 606s or Delco Iridiums.
  6. #6 Re: Knock Questions
    SE Level Member JB122894's Avatar
    May 2012
    Illinois
    sorry to thread jack but i just installed my scan gauge ii yesterday, and ive been watching my knock. it has sat at 0.0 for a long time even during wot. until later that night i got 1.5? im all stock. bad reading or just cuz its stock and freezing temps in chicago?
    1997 Grand Prix GTP
  7. #7 Re: Knock Questions
    GTX Level Member JDrach's Avatar
    Nov 2011
    Indiana
    colder the air, the more dense, the more boost from your SC. Either that or your knock sensor wasn't one. Usually its on either have such and such mins or temperature of the car when its warmed up.
  1. Two questions: Meth and knock? P0420 code?
    By jmackisback in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-04-2012, 07:59 AM
  2. Replies: 2
    Last Post: 01-30-2012, 09:40 AM
  3. Listen to the knock knock knock....
    By Lsick7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2011, 05:40 PM
  4. Alky Questions & Other Related Questions.
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2010, 07:57 AM
  5. Bad EGR = knock?
    By Sabrewings in forum General Tech Discussion
    Last Post: 07-31-2008, 07:13 PM
