So I had my buddy bring his scanner over to scan for knock, I thought I'd check it after all the plugs, wires, and coils I put in. Under normal conditions knock sat at 0. It came up to about 4 degrees at wide open throttle at around 50-60mph.
Can you tell me exactly what that means? Is that good? Bad? If its bad what's the best way to improve this?
Just as a reminder here's what I have. (I will update my sig with this now.)
180* T-Stat
PCM
CAI
3" DP w/U Bend Delete
2.5" Magnaflow Cat Back
I just put in all new coils, AC Delco wires and went with NGK Platinum stock heat range plugs. I did that because I was having the sputter issue and now its cured. Should I go back to my Autolite 104 copper?
Let me know what you think...
