Thread: Why does it take forever for my gt to heat up
Results 1 to 20 of 36
  1. #1 Why does it take forever for my gt to heat up
    Aug 2012
    Tukwila, Washington, United States
    I have two Grand Prix gt 3.8
    One is 98 and one is 99
    The 98 it take like 6 mins to hear and I can enjoy the heater and drive
    But the new 99 one I can wait even 20 min and it doesn't hit 180
    And the heater is ok but not hot and nice like the other 98.
    What is it? What do i need replaced?
    Grand Prix gt 1999 v6 3.8L coupe.
  2. #2 Re: Why does it take forever for my gt to heat up
    it the temp gauge's are rising at the same rate, id think the heater core is clogged up some.
    you take both hoses off the back of the alt bracket, but a garden hose up to one hose, it matters not which one, as you want to flush it via both hoses.
    when you have clear water flowing out as fast as it goes in your clear. hook the hoses back up. i like to keep as much water in the heater hoses as i can when i pop them back on, you'll loose some thats ok. doing this will help air from getting into the core.
  3. #3 Re: Why does it take forever for my gt to heat up
    GTX Level Member mofford12's Avatar
    Nov 2012
    Cincinnati
    thermostat is prolly stuck open.. mine had same issue
  4. #4 Re: Why does it take forever for my gt to heat up
    Aug 2012
    So what do I really need to do? Flush the system and replace the tstate?
  5. #5 Re: Why does it take forever for my gt to heat up
    once the car is warmed up, carefully touch the 2 hoses behind the engine, that go to the fire wall. if both are hot, like you cant hold it. the core is ok. if one is hot, and one is cold, you have air in the core or a clogged core. flush it then.
    now if both are hot, then id change the t stat. and in that case the engine temp would take longer to rise from a dead cold start vs your other car.
  6. #6 Re: Why does it take forever for my gt to heat up
    Donating User Odi's Avatar
    Chicago South Suburbs
    ^^ what he said, but you should replace the thermostat anyways if you havent yet. they tend to take a dump every so often.
  7. #7 Re: Why does it take forever for my gt to heat up
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    Sounds like a bad tstat
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  8. #8 Re: Why does it take forever for my gt to heat up
    Aug 2012
    ok ill do that. i hope its easy.
  9. #9 Re: Why does it take forever for my gt to heat up
    It's very easy.
  10. #10 Re: Why does it take forever for my gt to heat up
    Oct 2011
    Michigan
    Literary took me about 10 min the longest part of the job was waiting for the car to heat up
  11. #11 Re: Why does it take forever for my gt to heat up
    Sep 2011
    Copperas Cove, TEXAS
    Make sure to open the bleeder screw to let all the air out. Also you don't need any RTV, just make sure the mating surfaces are clean and put the gasket on dry.
  12. #12 Re: Why does it take forever for my gt to heat up
    Aug 2012
    But I have to flush the coolant before or I can just open the hose?
  13. #13 Re: Why does it take forever for my gt to heat up
    Resident ZZP Leg Humper BoostenGTP's Avatar
    Grand Rapids, MI
    nope, just unbolt the tstat housing and pull out old tstat, put new one in. bolt back down. plain and simple. i suggest doing this with the engine cold.
    2014 Mustang GT Sterling Grey 5.0 Track Package NEW 2000 Grand Prix GTP Red SOLD
    2000 Mustang GT LTR SOLD 2000 Grand Prix GTP Silvermist SOLD
  14. #14 Re: Why does it take forever for my gt to heat up
    Aug 2012
    Tnx
  15. #15 Re: Why does it take forever for my gt to heat up
    Oct 2011
    Michigan
    I didn't have any coolant come out of my motor just be careful and you won't make a mess
    also be sure to bleed the coolant before driving it
  16. #16 Re: Why does it take forever for my gt to heat up
    Aug 2012
    Quote Originally Posted by asite57 View Post
    What do u mean by that?
    U mean to get the air out?
  17. #17 Re: Why does it take forever for my gt to heat up
    you have a air bleeder screw a top the t stat housing, i like to idle ( rad cap off) the car and wait for the fans to come on, then bleed it, open the screw a few turns, shut the screw when a stream of coolant comes out, then top off the rad and cap it.
    when the fans are on, you can count on the t stat to be open, thats when you want to bleed it.
  18. #18 Re: Why does it take forever for my gt to heat up
    Aug 2012
    Ok tnx ill do that. So after air is coming out and it's starting to spray coolant that's the right time to close it?
  19. #19 Re: Why does it take forever for my gt to heat up
    yes. it wont spray, but it will bubble then piss out a small stream of coolant. one its solid stream shut it.
  20. #20 Re: Why does it take forever for my gt to heat up
    Aug 2012
    Ok cool.
  1. Car takes forever to warm up
    By Chadgervais in forum General Grand Prix Discussion
    Last Post: 01-29-2013, 08:02 PM
  2. Taking forever to warm up
    By Moe Dubs in forum General Tech Discussion
    Last Post: 11-09-2012, 01:38 PM
  3. Pontiacs forever!
    By Frostman in forum Introductions/Noob Questions
    Last Post: 09-08-2011, 09:22 PM
  4. Feels like FOREVER!
    By GTPontiacMan in forum Introductions/Noob Questions
    Last Post: 09-05-2011, 07:55 PM
  5. Done with the 3.8 FOREVER
    By KwazrollinZ28GTP in forum The Rant Forum
    Last Post: 05-13-2011, 01:53 AM
