Thread: check engine light...
Results 1 to 6 of 6
  1. #1 check engine light...
    Jun 2012
    Cedar Rapids, Iowa
    Code came up p0455 and said large leak.... and ever have this or is it a specfic thing..?
  2. #2 Re: check engine light...
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    google.com
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  3. #3 Re: check engine light...
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Or click on the little magnifying glass at the top of this page.
    1997 Red GTP 182000 miles stock
  4. #4 Re: check engine light...
    GT Level Member WolvesSoulZ's Avatar
    Québec
    Check your gas cap.
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  5. #5 Re: check engine light...
    Jun 2012
    Cedar Rapids, Iowa
    My gas cap is weird ill put gas then go screw it on and its hard to turn. Or sometimes on the trip computer it will say check gas cap.
  6. #6 Re: check engine light...
    Québec
    There you go, you found the cause of your code yourself, change your gas cap.
  1. Check engine light comes on then goes off
    By BeezyPlatt in forum 5.3L V8 (LS4)
    Last Post: 12-20-2012, 01:27 PM
  2. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  3. check engine light and lose wire in engine bay
    By Fcukit33 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2011, 05:29 AM
  4. Check engine light
    By Hawk656 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-16-2009, 04:13 PM
  5. check engine light
    By keenan00gtp in forum General Tech Discussion
    Last Post: 12-01-2008, 10:25 PM
