Thread: Are 2004 GTP's Governed?
Results 1 to 20 of 33
  1. #1 Are 2004 GTP's Governed?
    SE Level Member Iceman83's Avatar
    Jan 2013
    Livermore, KY
    If so, at what speed? And can the governor be de-programmed?
  2. #2 Re: Are 2004 GTP's Governed?
    antioch ill
    i wanna say its like 126
  3. #3 Re: Are 2004 GTP's Governed?
    Jan 2013
    Livermore, KY
    Huge step up from my '99 GT @ 105. lol.
  4. #4 Re: Are 2004 GTP's Governed?
    antioch ill
    my gtp sat at 110 forever tho and i let off thinking it was the speed limiter but i dont do top end runs to save my 4th gear
    125-126 iirc
    04 Comp G.
  6. #6 Re: Are 2004 GTP's Governed?
    Jan 2013
    Livermore, KY
    Supposedly my wife's aunt's 2002 GTP governor was turned off/de-programmed, or whatever, and went 160. I wasn't riding. But that's what she said. I called BS on that.
  7. #7 Re: Are 2004 GTP's Governed?
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Governed at 125 i wanna say.
  8. #8 Re: Are 2004 GTP's Governed?
    I just don't understand why people would want to drive that fast. Seems stupid to me.
  9. #9 Re: Are 2004 GTP's Governed?
    Jun 2011
    Top speed means nothing.
    Its all about acceleration i think.
    Quote Originally Posted by Iceman83 View Post
    B/S to that comp g top at at 145 so a standard GTP would be under that
    04 Comp G.
  11. #11 Re: Are 2004 GTP's Governed?
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    And your reasoning for that is?
  12. #12 Re: Are 2004 GTP's Governed?
    Jan 2013
    Livermore, KY
    I don't have to go that fast. I was just curious. I was once told as a teenager. It's not how fast you go. It's how fast you get there.
  13. #13 Re: Are 2004 GTP's Governed?
    Oct 2011
    Puyallup WA
    Yes all gtp's are governed comp g are higher and yes you can reprogram it for 200+
    08 G8 GT - exhaust Tune
    Quote Originally Posted by 231FUN View Post
    3.29 gears..
    04 Comp G.
  15. #15 Re: Are 2004 GTP's Governed?
    Dec 2011
    Ontario,Canada
    3.29 gears..
    Nope you got that backwards although you would probably hardly notice a difference top end. You accelerate quicker but sacrifice top end by going with a 3.29.
    You theoretically will run faster track times with 3.29 gears... .1 faster ET and 1mph slower for the gear change to 3.29
    http://www.w-body.com/showthread.php...-GTP-vs-Comp-G
    04 Comp G.
  17. #17 Re: Are 2004 GTP's Governed?
    May 2008
    Winnipeg, MB
    I know for a fact my car has done 131MPH with the mods it has, might go another 6MPH if I had a long enough road to test it on, accerlation is what wins races though.
    2007 Pontiac Grand Prix
  18. #18 Re: Are 2004 GTP's Governed?
    Dec 2011
    Ontario,Canada
    Hence why I asked what your reasoning was...
    You said because 3.29 gear.
    When you should have said because comp g is governed at a higher speed than a regular 2.93 geared gtp.
    So you would say that they both top off at the same mph?
    Actually a better questions whats the difference between a comp g and standard trans other then the gearing and tapshift? I believe nothing but correct me if I'm wrong.
    04 Comp G.
  20. #20 Re: Are 2004 GTP's Governed?
    GT Level Member tcman49's Avatar
    Apr 2011
    Palm Coast, Florida
    I have a 2001 GTP with standard engine, have hit about 110 mph plenty of times, it had a bit more so I think top speed of about 125 mph seems right.
  1. looking at a 2004 545 I
    By 01gpgt01 in forum Off Topic Discussion
    Last Post: 12-12-2012, 12:35 AM
  2. 2004 3.8 using oil
    By photomatt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-12-2012, 02:38 PM
  3. 2004 gto
    By 07CurbScraper in forum Track Sessions and Kills
    Last Post: 10-30-2011, 01:39 AM
  4. New HU in 2004 GP
    By GP04GT2 in forum Audio, Security & Visual Electronics
    Last Post: 12-19-2009, 01:25 PM
  5. 2004 lincoln Lsv8 or 2004 GP GTP?
    By Enjoijoe in forum General Tech Discussion
    Last Post: 03-10-2009, 03:58 PM
