Thread: Urgent! Troubleshooting vibration 00 GT
Results 1 to 6 of 6
  1. #1 Urgent! Troubleshooting vibration 00 GT
    St. Louis
    I need to know if a 15" steel rim from a 95 Bonneville will fit properly on my 00 GT. Reason being is I just found a pinhole leak in the nylon fuel line on the Bonneville, and the GP has been out of service due to a bad vibration somewhere (gets worse the faster you go, suspect a tire). Now that I cannot drive the Bonne I need to force the GP back onto the road so I can get to work tomorrow and have no time to get another set of 16" tires (if that is even the issue). If the 15's will work I want to swap the 2 fronts w/ the bonne wheels and see if this cures my vibration issue.
    And no, I won't leave it this way, and yes, I know my speedo will be off. The main point here is that I NEED a car for work tomorrow.
  2. #2 Re: Urgent! Troubleshooting vibration 00 GT
    If you swap both and do not have an aftermarket brake setup it will work.
  3. #3 Re: Urgent! Troubleshooting vibration 00 GT
    St. Louis
    Thanks FFDP. I have stock brakes on the GP. I just got one of the steelies on the GP as a test fit. It is def. tight clearance to the caliper, but does indeed fit as you stated. I just hope this solves the issue. I hate tracking down vibrations in FWD. Tires= easy fix. Something else- not so easy.
  4. #4 Re: Urgent! Troubleshooting vibration 00 GT
    St. Louis
    Well, just got them swapped and took it for a test drive. It appears to have made NO difference in the vibration/hopping feeling that I get under acceleration and any speed above 50. It seems to get worse when accel. and then subsides a bit when I let off and coast. The only other thing I can think of now is that I have a CV axle going bad. Neither of them have any torn boots or are leaking, but I did notice that I could get a bit of play on the pass side when I grab the half shaft and push down. Get a bit of a clunk from the inner joint. Could this be causing this horrible vibration/hop?
    I guess I'll get it on jackstands and see if the thing wobbles under accel. Kinda running out of ideas here.
  5. #5 Re: Urgent! Troubleshooting vibration 00 GT
    Charles City, IA
    Very well could be.
    SMGPFC Two Nipple General
  6. #6 Re: Urgent! Troubleshooting vibration 00 GT
    St. Louis
    Well, got the new pass. side axle in and took it for a drive. No more vibrations (well, no more than before) and runs smooth under accel and all the way up to 85. Thanks for the quick replies on this. Now I can get to work in the am.
    Once I got the old one out it was apparent that the inner was shot. Just flopped around and clunked when I shook it. The new one was nice a tight.
  1. URGENT What is this?!
    By PioneerGTP in forum General Tech Discussion
    Last Post: 10-09-2012, 04:49 PM
  2. Need Urgent Help
    By ahl395 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 03-18-2012, 11:50 PM
  3. Urgent Help Needed
    By tdm571 in forum General Tech Discussion
    Last Post: 04-08-2011, 08:53 AM
  4. Urgent help
    By milfadic in forum General Tech Discussion
    Last Post: 05-20-2010, 06:02 PM
  5. Urgent need of Help
    By Sunstone in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2008, 01:22 PM
