Thread: Urgent Help Needed
Results 1 to 9 of 9
  1. #1 Urgent Help Needed
    GT Level Member tdm571's Avatar
    Lakeside Park, KY
    All of a sudden, my blower motor will not turn off. The only way I can do it is to disconnect the battery. Obviously, this isn't a viable long term solution. I have to assume this is a wiring problem as it has to get power to run. TIA
  2. #2 Re: Urgent Help Needed
    GT Level Member gtcoup's Avatar
    Dec 2010
    plymouth ma
    replace the blower motor resistor.
    Smgpfc
  3. #3 Re: Urgent Help Needed
    ^^ unless there is a blower motor relay.
  4. #4 Re: Urgent Help Needed
    SE Level Member mikeplan14's Avatar
    Apr 2011
    Indiana
    happened on a previous '97 i had. replaced the resistor (under the pass side dash) for $40 and problem solved!... And I got fan speeds 1 through 3 back, which had been out for a year
  5. #5 Re: Urgent Help Needed
    Lakeside Park, KY
    How in the hell do you get to it without removing the dashboard?
  6. #6 Re: Urgent Help Needed
    Apr 2011
    Indiana
    Folded the passenger seat flat and basically laid on my back with my head in the footwell, under the dash. I think that I had to pull a trim panel off (2 fasteners), and then you can see the resistor. You have to unplug a harness to the motor, then you've got three screws to tackle. That will free the resistor. It took some time, as those screws were not easily accessible. 1/4" ratchet with some extensions and knuckles made the job possible.
  7. #7 Re: Urgent Help Needed
    Lakeside Park, KY
    Well, I got the sucker out of there. Made life easier to remove the blower motor too. Now I'm off to AZ to get a new one and see if that works. Still not sure how I'm gonna get that one hidden bolt back in there. I hate flying blind.
  8. #8 Re: Urgent Help Needed
    Lakeside Park, KY
    Got all the screws in and everything is back to the way it was. Thanks for the help guys!!!!!
  9. #9 Re: Urgent Help Needed
    Apr 2011
    Indiana
    Awesome! Glad to hear that everything's back working!... The blind screws are always the worst...
  1. CD player instal, parts needed, advice needed
    By timmaayy2323 in forum Audio, Security & Visual Electronics
    Last Post: 02-21-2011, 08:53 PM
  2. Urgent read ! Oil oil oil>
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 06-04-2010, 12:43 PM
  3. Urgent help
    By milfadic in forum General Tech Discussion
    Last Post: 05-20-2010, 06:02 PM
  4. urgent dead car
    By Sunstone in forum General Tech Discussion
    Last Post: 09-07-2008, 12:22 PM
  5. Urgent need of Help
    By Sunstone in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2008, 01:22 PM
