Thread: Couple weird issues
Results 1 to 16 of 16
  1. #1 Re: Couple weird issues
    Nov 2011
    NY
    Just a question... What made you change your O2 sensor in the first place? You neglect to mention that.
    Also, I really don't think an exhaust leak would cause the issue you describe, don't quote me though... But I agree maybe a broken vac line somewhere as that seems similar to what you are saying.
    Just my $.02
  2. #2 Re: Couple weird issues
    GT Level Member al2000gtp's Avatar
    Buda,IL
    I forgot to mention earlier that i did try running it with the maf unhooked and it only got worse so i plugged it back in and the reason i changed the o2 was because i kept throwing a po135, po141, and p1133. Has not thrown any codes at all since i changed the o2. and about the vac lines, ive checked them all and they all seem good and they are all brand new. i thought if you saw positive ltft it was usually vac leak and negative ltft means exhaust leak. i dont see any positive numbers since new o2, all negative.
    2000 GTP - HAI, SD Headers, 3" catback, cat delete, thrush turbo muffs, self ported sc, and transgo shift kit.
  1. Couple of issues with my 01 GT I just purchased.
    By gold01gt in forum General Tech Discussion
    Last Post: 02-20-2012, 07:05 AM
  2. having a couple issues
    By gtcoup in forum General Tech Discussion
    Last Post: 03-05-2011, 11:59 PM
  3. couple of questions, couple of issues
    By zero in forum General Tech Discussion
    Last Post: 12-30-2009, 04:48 PM
  4. Couple of issues I need to diagnose
    By FlaminWhite97GTP in forum General Tech Discussion
    Last Post: 12-02-2009, 11:20 PM
  5. Couple Issues
    By BwolfGT in forum General Tech Discussion
    Last Post: 07-29-2009, 09:45 PM
