Thread: The problems continue...
Results 1 to 6 of 6
  1. #1 The problems continue...
    SE Level Member Bragill25's Avatar
    Sep 2012
    Michigan
    Had to fix the fuel pump, blower resistor, and other small things. Now i found out i have to fix the intake manifold, gas/ brake lines, rocker panels, and oil pan. Not cheap. Are these common problems or did i just get lucky.? Plus are any of them something i can do by myself rather a dealer? If so, what kind of brands are reliable? Any help of any of the questions would be greatly appreciated. Thanks!
    Ohio
    Everything you listed are gp problems
  3. #3 Re: The problems continue...
    St. Louis
    What year and model (GT or GTP) is your car. Aside from that, yes, you can do all of that yourself. There is plenty of writeups here to replace the LIM gaskets and the other parts that go with it. Oil pan is a PITA (have to jack the motor up a bit). Brake and fuel lines can be done. Rocker panels (depending on your welding and body work skills) can be done as well, minus any paint.
  4. #4 Re: The problems continue...
    Sep 2012
    Michigan
    97 GTP
    But thanks ill be sure to go look for some and see what its like.
  5. #5 Re: The problems continue...
    St. Louis
    If you haven't found it, the main search bar is hidden in the black part at the top of the forum up and left from the red GP. You can also search in each forum to narrow it down. Worst case, just ask us and we can fill in the blanks.
  6. #6 Re: The problems continue...
    Quote Originally Posted by 99pgpgt View Post
    Odd..I thought they were common to 3800's in general....lol
    It's normal enough if maintenance was negleted.
  1. ABS Problems
    By Logan541 in forum Brakes/Suspension/Chassis
    Last Post: 12-12-2011, 05:49 AM
  2. How does jeep continue to ship wranglers with the wrong parts?
    By Explicit_Spade in forum Off Topic Discussion
    Last Post: 09-16-2011, 05:58 PM
  3. Continue with SC or go Turbo?
    By Amb4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-18-2010, 10:13 PM
  4. Problems with 98 GTP?
    By splinter in forum General Tech Discussion
    Last Post: 01-14-2010, 06:00 PM
  5. problems problems problems!
    By NomeCrusher in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-14-2009, 03:26 PM
