If... And a big IF the crank sensor doesn't fix the problem, the wiring harness near the PCM that passes the evap/condenser gets uncomfortably close and over time can rot out wires from HEAT in that portion of the harness (experience).
If all else fails, you can check there (but only as a last resort).
