Thread: 01 gtp misfire and rpm drops
Results 1 to 13 of 13
  1. #1 01 gtp misfire and rpm drops
    SE Level Member samuelcb409's Avatar
    Galveston, Texas
    Current mods:
    3.4 mps
    180 tstat
    Speed daddy headers
    Egr, cat & ubend delete
    3" dp
    magnaflow mufflers
    ngk iriduim plugs and prj wires
    custom tune by zack
    new coils
    k&n intake
    zzp tb spacer
    started yesterday when driving and come to stop or just idling rpm drops and goes back up. Had the window down and heard it puff in the exhaust so maybe a misfire. Happened before when i had AL104s. Thought it was plugs changed to iridiums.. But happened again. Could it be the wires gone bad.. Please lmk asap
    MODS: 3.0 MPS, CAI, SD Headers w/Custom 3"DP, 160* T-Stat, NGK TR6, Full Size intercooler, #42.5s, Ported LIM & Gen III, LS1 TB w/85mm MAF , s1x Cam, #90 Springs, Intense Pushrods, EGR Delete, Cat and U Bend Delete, Magnaflow Resonator & Mufflers, Fully Built ZZP Trans, 2800 stall Tuned by KHP Peformance
  2. #2 Re: 01 gtp misfire and rpm drops
    Kinda vague here really...any check engine lights?
    A video of what is happening?
    You should be running colder plugs on a smaller pulley...not factory iriddy's.
    AL104's...gapped at .050-.055"...also...get rid of that TB spacer that is doing you nothing good but causing the rear bank of cylinders to get hotter than the front. How did the plugs look when you pulled them out before hand?
  3. #3 Re: 01 gtp misfire and rpm drops
    Galveston, Texas
    No check engine.. Plugs looked ok no signs or any damage
  4. #4 Re: 01 gtp misfire and rpm drops
    Random question...since you don't have a cat...are you running an o2 sim?
  5. #5 Re: 01 gtp misfire and rpm drops
    Galveston, Texas
    not sure if they put one in when they did my headers, etc... ill check it out this afternoon when i get home from work... i dont think so they just tuned out the cat and kept stock o2 sensor
  6. #6 Re: 01 gtp misfire and rpm drops
    It's an '01+ car...they can't tune out the cat diagnostics AFAIK.
  7. #7 Re: 01 gtp misfire and rpm drops
    Galveston, Texas
    It also started holding back at full throttle..
  8. #8 Re: 01 gtp misfire and rpm drops
    Galveston, Texas
    got the throttle issue fixed but still misfiring at random times, put new plugs al104s gapped at .55, new oem wires, new pcv value, fuel filter and oil changed, replaced the coils before when this first started happening then one plug went bad and it was ok at first then started doing the rpm drops. throttle body spacer gonna be removed tomorrow... any thoughts
  9. #9 Re: 01 gtp misfire and rpm drops
    Vac leak at the TB spacer?
    They are junk afterall.
    Also...what do you mean by "one plug went bad" ?
  10. #10 Re: 01 gtp misfire and rpm drops
    Galveston, Texas
    It was crack when took the boot off
  11. #11 Re: 01 gtp misfire and rpm drops
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    Same issues im having. Same exact mods except spacer
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  12. #12 Re: 01 gtp misfire and rpm drops
    Galveston, Texas
    Sometimes car feels sluggish then other times its fine.. Not sure what could be.going on... Would i have to do a retune since i changed from ngks and msd wire back to al104s and oem wires
  13. #13 Re: 01 gtp misfire and rpm drops
    Galveston, Texas
    Any thoughts on what it might be
  1. rpm drops
    By PhunnyJesta in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2011, 06:16 PM
  2. Fixed Idle problem Now the rpm drops and brakes pull help
    By PTGsDaytona500GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-25-2010, 07:14 AM
  3. Grounding points // Voltage Drops...
    By Toofastgs in forum Audio, Security & Visual Electronics
    Last Post: 09-09-2008, 09:21 PM
  4. Replies: 5
    Last Post: 05-12-2008, 01:51 AM
