Thread: Fogged headlights
Results 1 to 6 of 6
  1. #1 Fogged headlights
    SE Level Member Scott Gerhart's Avatar
    Aug 2012
    Reading, PA
    What do you guys use to fix your fogged headlights? Anyone have newer headlights for a 2004 Grand Prix?
  2. #2 Re: Fogged headlights
    The cheap fix is to sand them down starting with whatever to remove any deep scratches and working your way up to either 1500 or 2000 grit then laying some Duplicolor clear over them. That seems to remove the hazing and stuff from the outside of the lens.
    Aug 2012
    Reading, PA
    What is duplicolor?
    Indiana
    It's a brand of paint. I think there are better clears out there tho. I think Drunkie did a writeup on redoing them. Sandint and I think he put polyurethane on them.
  5. #5 Re: Fogged headlights
    a orbital buff will take the haze off. i used a porter cable buffer with liquid compound, they cleared up nice.
    they were hazed up more then this pic shows.
    after buffing.
  6. #6 Re: Fogged headlights
    GTP Level Member Lishap's Avatar
    Jan 2012
    New York
  1. No headlights or dash lights when the headlights are turned on. HELP!
    By steeck1 in forum Audio, Security & Visual Electronics
    Last Post: 06-23-2012, 12:08 PM
  2. Headlight Fogged, need advice now
    By JorgeRuiz in forum Visual/Body Modifications
    Last Post: 03-25-2011, 09:45 PM
  3. fogged corners
    By chickenfried in forum Visual/Body Modifications
    Last Post: 09-25-2010, 09:49 AM
  4. HID Headlights, not sure!
    By jjwalton77 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-24-2010, 12:18 PM
