Thread: intermentant AC problem
Results 1 to 4 of 4
  1. #1 intermentant AC problem
    port charlotte fl.
    I have a 2000 GP and the AC will go off for 1 or 2 seconds and come back on. The air temp seems to be ok. I am no sure where to look first to solve this intermentant problem.
  2. #2 Re: intermentant AC problem
    St. Louis
    You mean you hear the compressor shut off for a few seconds and then come back on? That's normal cycling by the compressor. It doesn't run all the time. Just when it is needed to maintain the coolness you selected. If the temp of the air from the vents never gets warm then I'd say you're good.
  3. #3 Re: intermentant AC problem
    port charlotte fl.
    not sure if the compressor shuts off because it happens so fast, but the blower does. Im woundering if the whole AC curcuit would shut down momentarily for any reason.
  4. #4 Re: intermentant AC problem
    St. Louis
    Check the wiring that connects to the blower motor. Have the blower on and wiggle the wires. If it shuts off then you found the issue. It's been known to happen on these cars.
  1. Is it a problem on my end? Picture Uploading Problem.
    By TJeno in forum Forum Bugs/Suggestions
    Last Post: 10-23-2012, 07:53 AM
  2. intermentant AC problem
    By john breit in forum General Tech Discussion
    Last Post: 09-02-2012, 01:44 PM
  3. Problem with transmission NO REVERSE...Any suggestions of problem
    By newmy1d in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2012, 11:36 AM
  4. anyone had this problem?
    By steelholder in forum General Tech Discussion
    Last Post: 04-29-2011, 05:04 PM
  5. Abs/tcs problem
    By L KELLS in forum General Tech Discussion
    Last Post: 01-04-2010, 04:51 PM
