Thread: Front End Noise
Results 1 to 7 of 7
  1. #1 Front End Noise
    Jul 2012
    Buffalo NY
    My 2002 was making a noise similar to wear indicators but the brakes were fine. I narrowed it down to a bracket rubbing on the inside rotor face. This bracket seems to act as a shim between the hub and knuckle and is used to route the ABS wire. The bracket is shown in the bottom of this picture. http://www.grandprixforums.net/how-r...ubs-10985.html
    Any advice?
  2. #2 Re: Front End Noise
    Apr 2009
    Fort Worth TX
    It's bent. Bend it back.
  3. #3 Re: Front End Noise
    Jul 2012
    Grand rapids
    Advise bend it back when someone did a wheel bearing or something with the front end and bent it
  4. #4 Re: Front End Noise
    GT Level Member Toms04compg's Avatar
    Michigan
    How does the inside of the rotor look?
  5. #5 Re: Front End Noise
    Jul 2012
    Buffalo NY
    Quote Originally Posted by Rico View Post
    That is what I thought but I can't explain how both sides could have been bent at the sames time. I did have the bearings replaced about 100,000 mile ago.
  6. #6 Re: Front End Noise
    Jul 2012
    Buffalo NY
    Quote Originally Posted by Toms04compg View Post
    It looks ok. The bracket however is worn down.
  7. #7 Re: Front End Noise
    Apr 2009
    Fort Worth TX
    Bend the brackets back and make sure there is clearance between it and the rotor. It's just that simple.
  1. Front end noise
    By nikkigpgt00 in forum General Tech Discussion
    Last Post: 09-13-2011, 07:17 AM
  2. Front end noise
    By GTP2188 in forum Brakes/Suspension/Chassis
    Last Post: 02-22-2011, 01:06 PM
  3. Front end noise
    By squirrel in forum Introductions/Noob Questions
    Last Post: 08-16-2010, 10:50 PM
  4. front end noise, what else...?
    By Jakegday in forum General Tech Discussion
    Last Post: 07-30-2010, 08:22 PM
  5. front end noise, hub?
    By hourang in forum Brakes/Suspension/Chassis
    Last Post: 02-01-2010, 11:17 AM
