Thread: Need some direction on hooking up gauges!!!!!!!!!
Results 1 to 12 of 12
  1. #1 Need some direction on hooking up gauges!!!!!!!!!
    Mar 2012
    Maryland
    hey guys i have 3 gauges i want to install ! but never done it, oil pressure, oil temp, water temp, they are already on the pod and in the car but not yet reading, where do i hook them in the engine??? thanks
    Please Adjust your signature as it is too large. Thank you.
  2. #2 Re: Need some direction on hooking up gauges!!!!!!!!!
    SE Level Member Sean1998Daytona's Avatar
    Mar 2012
    Milwaukee, Wisconsin
    Whered u get those blue spark plug wires??
  3. #3 Re: Need some direction on hooking up gauges!!!!!!!!!
    Mar 2012
    Maryland
    from 3800performance.com bro, they are 10.4 mm great quality wires
  4. #4 Re: Need some direction on hooking up gauges!!!!!!!!!
    Mar 2012
    ok sweet. do you have to do anything special to your engine if you go from 7.5 mm to 10.5 mm? and are they difficult to install?
  5. #5 Re: Need some direction on hooking up gauges!!!!!!!!!
    Mar 2012
    Maryland
    no bro they get install just about the same way as the stock wires the only thing to look out is at the front where the headers go if you have them, for the boot on the right to not touch the header, but couple of wire plug placers should do the job
  6. #6 Re: Need some direction on hooking up gauges!!!!!!!!!
    Jan 2012
    Philadelphia
    wires are not to bad to install, just be careful not to brake the metal off your old ones in the rear of the engine while taking them off. I dont know if it would hurt to jump from 7.5mm to 10.5mm, i dont really see how it could, but its not necessary really to have them unless you have lots of performance mods. But they look cool lol
  7. #7 Re: Need some direction on hooking up gauges!!!!!!!!!
    Mar 2012
    Maryland
    yes is true, i run NGK plugs and have lot of mods but to run them on a stock car it wont hurt anything, i usually move the boots from right to left just to brake them lose before pulling them and always works great, dont forget to put back your heat boot shields back tho lol
  8. #8 Re: Need some direction on hooking up gauges!!!!!!!!!
    Mar 2012
    Maryland
    any of you guys can help me with the gauges install?
  9. #9 Re: Need some direction on hooking up gauges!!!!!!!!!
    Search on here for install pics and stuff.
    Also, take that breather off the valve cover if you arent running an intercooler. Its a pointless mod and not helping the car in any way.
  10. #10 Re: Need some direction on hooking up gauges!!!!!!!!!
    Mar 2012
    Maryland
    oh i know that, it was for looks at the pic, i dont run the car with it, but thanks for the advise
  11. #11 Re: Need some direction on hooking up gauges!!!!!!!!!
    Oil pressure you need an oil pressure sending unit with adapter to fit in the hole where the OEM unit is for the car to read. That is located in back on the neck for the oil filter.
    Water temp you could tap the coolant temp sensor in the front by the major inlet on the LIM
    Not sure on oil temp
    Honestly I would be running Oil pressure, Boost and wideband or Aeroforce (aeroforce has all the info you need like fuel trims, coolant temp, etc)
    I have 4 From top to bottom: Wideband, Oil pressure, Boost and in the vent hole is my aeroforce
  12. #12 Re: Need some direction on hooking up gauges!!!!!!!!!
    Mar 2012
    Maryland
    thanks bro that info helps me a hell of a lot!!!!!
  1. Dual Climate Control - Direction
    By ARFF22 in forum General Tech Discussion
    Last Post: 07-17-2012, 07:24 PM
  2. Any way to adjust fog light direction?
    By RotyP in forum 04+ Specifics
    Last Post: 04-14-2011, 10:16 PM
  3. gtp modding direction
    By eddyman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2010, 05:24 AM
  4. hooking up gauges
    By GTPRiley in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-03-2008, 03:07 PM
  5. Movement in the other direction!
    By GPGT08 in forum Tires & Wheels
    Last Post: 07-01-2008, 05:06 PM
