Quote Originally Posted by tomtom123 View Post
"Keep in mind that more is not always better. You'll just want enough octane booster to stop your KR. Any more than that could hurt performance. There's not as much energy in 94 octane gas as there is in 89 octane. Typically all higher octane gas does is slow down the combustion rate. That's why it's probably best to run what the manufacturer says to run.
Good Luck Toulene
R+M/2...114
Cost...$2.50/gal
Mixtures with 92 Octane Premium
10%...94.2 Octane
20%...96.4 Octane
30%...98.6 Octane
Notes: Common ingredient in Octane Boosters in a can. 12-16 ounces will only raise octane 2-3 *points*, I.e. from 92 to 92.3. Often costs $3-5 for 12-16 ounces, when it can be purchased for less than $3/gal at chemical supply houses or paint stores.
FORMULA 2
Xylene
R+M/2...117
Cost...$2.75/gal
10%...94.5 OctanE
20%...97.0 Octane
30%...99.5 Octane
Notes: Similar to Toulene. 12-16 ounces will only raise octane 2-3 *points*, I.e. from 92 to 92.3. Usually mixed with Toulene and advertised as *race formula*.
MAKE YOUR OWN OCTANE BOOSTER
How to make your own octane booster (this is the basic formula of one of the popular octane booster products). To make eight 16 ounce bottles (128 oz = 1 gal):
100 oz of toulene for octane boost
25 oz of mineral spirits (cleaning agent)
3 oz of transmission fluid (lubricating agent)
This product is advertised as "octane booster with cleaning agent *and* lubricating agent!". Diesel fuel or kerosene can be substituted for mineral spirits and light turbine oil can be substituted for transmission fluid. Color can be added with petroleum dyes."
From the forums here =)
This isn't an octane booster. You didn't look at the link did you? The link was for ethanol remover. Also, I do get better mpg< along with many other people, letting the engine warm up for a few mins
