I was getting about 22 all hiway and now its averaging almost 20 stop and go! But i've only had it a week
Did 204 miles round trip up north to the cabin today, filled up before I left and re-fueled once we got home.
Pump clicked off at 8.7ish gallon used and after the math it just about 23 MPG. I was very suprised how well it did on the freeway, most of the driving was at 66-68 mph and about 60 miles was county roads at 55-60 mph. Some cruise control used on the way up and really none on the way back, motor is just bumming along at 1700-1800 rpms.
All that with a lowered 06 Sierra 2WD with now over 256,000 miles on the motor.
I'm probably getting 12-14mpg with a faulty o2 sensor and my rear o2 not tuned out plus running NGK plugs which I feel saps some mileage too. Getting it all straightend this weekend.
Let's see...on last tank I got 26.7mpg...seems to be the standard for this car as it doesn't really seem affected by highway or country driving with some beating in there. I'm sure the 6 speed helps as I tach less than 2k at 80mph...around 1500rpm at 60mph.
I just managed 26.2mpg on my gtp ladt weekend when I went up north. Pretty happy with that.
got 29.5 mpgs going 70 from brainerd mn to minneapolis mn, a good 2 and half hour drive in my 01 gt with 56k miles. was fairly happy.
My mpgs went up to 33 from 29 highway after a tune yay
Sent from the Milky Way
I get about 24-25mpg highway cruising at 72.
About 10-15mpg city driving.
Running headers, 3.4 pulley, 1.8 rockers, CAI, 160 T-stat.....I get about 25 on the highway doing between 70-75 ( DIC is extremely close to math based results ). About time I bump up to a warmer T-stat for the colder winter.....may do that this weekend.
Thing that irritates me is the gas gauge being off. These cars came with a 18 gallon tank. My gauge thinks its a 12-13 gallon tank. At 1/2 tank, I fight to get 6-ish gallons in it. The gauge goes to "full-ish ", but, I can never get it to peg the needle out much less barely get it to the Full line. Gauge always reads a little higher at start up, too. Falls a little even sitting still and idling for a minute or so. I know I got at least a 400 mile range capacity, but, when those little lights go off saying I need gas....I just can't bring myself to push it out.
Still on the original sender? Mine was always pretty accurate as far as gm's go. A few lines above e, I always get about 14.5-14.8 gallons in. Just meaning that on e has about 2-2.5 gallons left. I recently replaced mine with a dorman unit which consistently reads a few lines higher than the stock unit did at the same fuel level. Not sure how I feel about that. I guess I'd only have 1.5 ish gallons on e now
According to the DIC I've averaged 22.8 in the past month or so, which is pretty accurate - when I fill up, I get about 22 in the black car.
I had about 28 in both the Regal and the LeSabre.
And the Prius... 50, all day long. There's a reason why I haven't sold that car
I thought the tanks were 16.9,I figured with my dic 1 quarter is 4 gallons, I used the gallons used and it was at 4 and it was almost a quarter gone
About 25-27 mpg.
I really enjoy the trans settings. Sadly my commute mpgs haven't changed because fking hills suck. Plus with it being colder I've been losing some MPGs
Sent from BFE
I get usually between 26 - 30 highway doing between 75 - 78.
Comp Cam 76-802-9
3.4" + headers and supporting mods. 93 octane.
23mpg 47mph left in 3rd. Saw 23.1 a few times but boost. 5 stop lights and 3 stop signs on my 12mile 1 way journey
I got 29.6 on my last fill up on standard gt no mods - but a slight misfire that I haven't gotten around to fixing.
Filled up earlier tonight for 31.2 still slight misfire.
Filled up 14.27 gallons, at $2.89/Gal for regular at shell. Got 16.6 mpg on that last tank.
