Thread: Flashing security light; immediately dies
Results 1 to 2 of 2
  1. #1 Flashing security light; immediately dies
    Mar 2019
    IA
    First and foremost I would like to thank the administrators of this website for allowing me to join and create threads..
    This is greatly appreciated!
    One month ago it was absolutely freezing outside with a windchill of -25. I hopped in my car and while it was slowly cranking it did finally turn over.
    As I let her warm up for awhile I noticed the “security” light was solid. I arrived at ny destination, shut the vehicle off and returned to my vehicle 20 minutes later to you guessed it, immediately die and “security” light flashing.
    I had it towed to the dealership and they claimed the anti-theft control module needed replaced. I bought the part on RockAuto and they installed it; car ran fine.
    Monday morning I hopped in the car (yes, it was cold) and this time it started, but immediately died.
    I tried the 3 ten minute reset to no avail.
    This morning I purchased PERMANENTLY Disable and Remove GM Security Systems module as I don’t know what else to do.
    Why is this happening?
    Is there something I can try to at least get the car rolling temporarily?
    Thank you all in advance!
    2002 Pontiac Grand Prix GT 3.8
    98k miles
  2. #2 Re: Flashing security light; immediately dies
    did you do the security learn 3 times? or just once? how is the battery? sounds like its on the weak side.
    security learn is key to run for 10 minutes off for less then 5 seconds and back to run for 10 minutes tree times. you cant open the doors or mess with the radio or anything, if the battery cant stay alive for 30 minutes key to run, have a charger on it, or jumper cables off a running car to keep your battery up to 12 volts during this.
    i like to open the window and work the key from outside, cause who wants to be stuck inside the car for that long, use a timer on your phone. the off then back on, i turn it off for like 2 seconds and back to run.
  1. Flashing SECURITY Light
    By awui2014 in forum Audio, Security & Visual Electronics
    Last Post: 02-28-2018, 10:30 PM
  2. Flashing security light
    By smitz327 in forum Audio, Security & Visual Electronics
    Last Post: 11-21-2014, 08:22 PM
  3. security light flashing
    By 01gtp1506 in forum General Grand Prix Discussion
    Last Post: 07-17-2013, 05:25 AM
  4. Replies: 5
    Last Post: 10-04-2012, 02:40 PM
  5. Security light flashing
    By Bunty in forum General Tech Discussion
    Last Post: 12-22-2010, 04:38 PM
