Thread: Parts compatibility
Results 1 to 4 of 4
  1. #1 Parts compatibility
    Mar 2019
    Alaska
    Looking to grab parts from an '05 Grand Prix for my '04 and wondering if they're cross-compatible or not? Lower plastic portion of rear bumber, ABS control module, side view mirror glass, body panels / trim, weather stripping. Thanks!
  2. #2 Re: Parts compatibility
    Jul 2017
    macomb mi
    Quote Originally Posted by HueyThump View Post
    yes 04-08 are all pretty identical only difference will be certain things between supercharged and non-supercharged models. all the parts you listed should be identical except the ABS you'll have to have the same amount of prongs and I believe they have to be programmed to your vin if I remember. I had a bad ABS I think I ordered one programmed to my car for like $100 from some website then once it came I swapped them out and sent the bad one for a core charge.
    2004 gtp SD headers, e85, #60 injectors, Walbroh 255lph, junkyard custom fender well intake, lq4 MAF, 2.8 Pulley, 1.95 rockers, l76 springs, ssic w/ vw rad shift kit and tranny cooler 275/45r17. BMR trailing and rear control arms, zzp STB's, tubular control arms, Dorman and Addoco sway bars, intense coilovers, all poly. avid av-20s
  3. #3 Re: Parts compatibility
    Mar 2019
    Alaska
    Groovy, thanks! Personally, I'd prefer to not have the ABS working because I don't like sliding around on icy roads. BUT, since that little module seems to control so many other bells that go off after I start the car...I might have to give in.
  4. #4 Re: Parts compatibility
    Jul 2017
    macomb mi
    yea that thing annoyed the crap out of me beeped super loud every time I got in worth the $100 to keep my insanity plus for some weird reason made my power steering easier than my moms 2018 escape so that was a bonus made it silky smooth like zohan haha
  1. Compatibility
    By whitegt956 in forum Introductions/Noob Questions
    Last Post: 08-25-2013, 12:39 PM
  2. (In)compatibility
    By Dr Cedric in forum Introductions/Noob Questions
    Last Post: 08-25-2013, 12:21 AM
  3. Parts Compatibility
    By w98seeng in forum General Tech Discussion
    Last Post: 02-12-2012, 06:07 PM
  4. MAF compatibility
    By benner in forum General Tech Discussion
    Last Post: 06-13-2010, 05:34 PM
  5. Compatibility
    By Skeeve in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-19-2009, 02:34 PM
