Thread: Replace injectors help
Results 1 to 13 of 13
  1. #1 Replace injectors help
    Jan 2018
    Morgantown
    what's the easiest way to replace the rear spark plugs and #4 cylinder injector its bad
  2. #2 Re: Replace injectors help
    The Boss Iceman6669's Avatar
    Jun 2011
    Rear plugs are pretty straight forward... If you need to you can remove the dog bones and rock the motor forward to give yourself a little more space.
    replacing injectors is also pretty easy. Fuel rail comes off, injector clip comes off, injector pops out. Id replace the orings on the injectors before reinstalling them myself.
    2011 F-150 Yote powered
  3. #3 Re: Replace injectors help
    Jan 2018
    Morgantown
    Quote Originally Posted by Iceman6669 View Post
    Oh okay I didn't know I can barely see them thanks
  4. #4 Re: Replace injectors help
    dog bone on the coil bracket. remove the bolt engine side, now you'll notice a extra hole there where it was bolted on, put the bolt back in the dog bone only, pull engine forward and pop the bolt end in that extra hole, it will hold the engine forward a bit for ya.
    back plugs you do 1/2 blind, reach in there pull the wire off, push the socket on the plug first, then i use a 3 inch extension on my ratchet. break it free, ratchet off remove by hand.
  5. #5 Re: Replace injectors help
    oh, you need to remove the bolt on the other sides dog bone or it wont move forward for ya lol its the details.....
  6. #6 Re: Replace injectors help
    Jan 2018
    Morgantown
    Well I screwed up bad got dirt and stuff down in the injector holes what do I do now I'm racking my mind it wasn't just a little either
  7. #7 Re: Replace injectors help
    Jun 2011
    If it’s enough to concern you, leave the plug out, pull the fuse for the fuel pump, and turn the motor over a few times. Let the motor blow the crap out.
  8. #8 Re: Replace injectors help
    GT Level Member Pursell1911's Avatar
    Jan 2017
    Louisville, Kentucky
    Wouldn't that be if he got dirt in the spark plug hole?
    2006 Grand Prix GT - 3" Downpipe | DIY Intake
  9. #9 Re: Replace injectors help
    just fire it up, its just dirt.
    i take the cap off a brake cleaner can, spray brake cleaner in said cap, watch your eyes for blow back, then use Q tips dipped in b/c then clean out the holes. its gonna take a few q tips per hole. you can bunch up 2-3 at a time and use as a larger swab.
  10. #10 Re: Replace injectors help
    Jun 2011
    Quote Originally Posted by Pursell1911 View Post
    Thats I guess what I assumed he was talking about, but even if he got dirt in the injector hole, same basic idea applies. Leave the spark plug off and turn the motor over (once it is made so it wont start) and it will clear all the crap outta there.
  11. #11 Re: Replace injectors help
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    For future reference, I always bare minimum vacuum around the top of the engine, and preferably do that and clean the engine bay just to be sure, but what ice said will work great if you forgot and got stuff inside too!
  12. #12 Re: Replace injectors help
    Jan 2018
    Morgantown
    Quote Originally Posted by wstefan20 View Post
    Yea I did that but thought it wasn't as bad as it was
  13. #13 Re: Replace injectors help
    blowing them out works better, like compressed air. them cans of air duster might just have enough power to blow them clean too. then pull the rail and injectors out. then clean the holes with q tips and brake cleaner.
  1. should i fix this car or replace
    By mysticclam in forum Introductions/Noob Questions
    Last Post: 08-03-2014, 04:09 PM
  2. What should I replace?
    By loopy smurf in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-24-2013, 07:21 PM
  3. 3,1 to replace 3.8 in 98' GT?????
    By Dan Hammes in forum General Tech Discussion
    Last Post: 09-14-2012, 04:58 PM
  4. How Do I Replace the FRP?
    By TZ250 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-27-2008, 11:07 PM
