Thread: 97 GTP ECM wire harnes
Results 1 to 7 of 7
  1. #1 97 GTP ECM wire harnes
    Aug 2017
    Michigan
    I am splicing in an blue side ECM harness but whats messing me up is some of the wires have 2 - 3 of the same color wires, how can you figure out which wire go to which pin on the ecm harness there are multiple of 2 or 3 wires of the same color on that blue connector and no way to tell the difference between them!
    Can anybody tell me a way to figure this out?
  2. #2 Re: 97 GTP ECM wire harnes
    Oct 2014
    portland oregon
    Did you cut them all off before labeling each one with pin number? If so Yikes.
    Im not sure if a wire diagram would help.
    Maybe someone else has a fix for you but I dont think its looking good my friend
  3. #3 Re: 97 GTP ECM wire harnes
    Aug 2017
    Michigan
    Nope I did not label them so I am screwed
  4. #4 Re: 97 GTP ECM wire harnes
    Oct 2014
    portland oregon
    I went and looked at mine. I didnt take it apart IIRC the blue one is the bottom of the pcm
    Just by looking I seen 2 green wires and one has a white stripe on it also, there are 2 banks of wires that feed into the one harness so maybe you can use a process of elimination to right this ship.
  5. #5 Re: 97 GTP ECM wire harnes
    Aug 2017
    Michigan
    Thats what I have been trying all day on that blue side of the harness there are 2 blue wires with black stripes, 2 yellow wires, 3 drk green with white lines, 2 red with black line, 2 solid gray and 2 solid purple on 1 side of the harness so I been switching between them earlier today.
    Right now when I turn the car on it idle real high, you can hear the air being sucked into the intake cause its really loud when I shift into drive or reverse the trans hits into gear really hard you can hear it and the boost gauge is missing from the info center on the dash.
    I am not sure if some of these issues is because of the zzp ECM i am trying out I might put back in my original ecm and figure out what wires go with what while using the OEM ECM
    I matched up all other wires on the harness just not sure on the ones that have 2-3 of the same color so I swithed back and fourth some of those wires a couple of times
  6. #6 Re: 97 GTP ECM wire harnes
  7. #7 Re: 97 GTP ECM wire harnes
    Aug 2017
    Michigan
    Thanks for the pics I just could not get the pic for wires 28-52 But I finally got her running right yesterday still not sure on 2-4 of those wires and the 3 green and white ones cause 1 wire out the 3 suppose to be for the EGR and the other 2 are just for the AC but she is running I might have to go visit ZZP to get a case learn for the ECM I got from them cause the check engine light is on but they say 97 dont need it
  1. Want to wire in dash cam, what 12v wire?
    By genki in forum Audio, Security & Visual Electronics
    Last Post: 05-27-2015, 10:10 PM
  2. Looking for some speaker wire and a new ground wire.
    By Bluemagic in forum Audio, Security & Visual Electronics
    Last Post: 01-19-2013, 08:41 PM
  3. Replies: 3
    Last Post: 01-06-2013, 10:53 PM
  4. Where is rear defogger relay wire? (and trunk relay wire)
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 11-02-2011, 03:10 PM
  5. Brian Teel on this forum?... need some 97-98 harnes/pcm info.
    By Tengis in forum Off Topic Discussion
    Last Post: 12-21-2008, 03:39 AM
