Thread: 97 GTP ECM wire harnes
Results 1 to 7 of 7
Threaded View
  1. #5 Re: 97 GTP ECM wire harnes
    Aug 2017
    Michigan
    Thats what I have been trying all day on that blue side of the harness there are 2 blue wires with black stripes, 2 yellow wires, 3 drk green with white lines, 2 red with black line, 2 solid gray and 2 solid purple on 1 side of the harness so I been switching between them earlier today.
    Right now when I turn the car on it idle real high, you can hear the air being sucked into the intake cause its really loud when I shift into drive or reverse the trans hits into gear really hard you can hear it and the boost gauge is missing from the info center on the dash.
    I am not sure if some of these issues is because of the zzp ECM i am trying out I might put back in my original ecm and figure out what wires go with what while using the OEM ECM
    I matched up all other wires on the harness just not sure on the ones that have 2-3 of the same color so I swithed back and fourth some of those wires a couple of times
  1. Want to wire in dash cam, what 12v wire?
    By genki in forum Audio, Security & Visual Electronics
    Last Post: 05-27-2015, 10:10 PM
  2. Looking for some speaker wire and a new ground wire.
    By Bluemagic in forum Audio, Security & Visual Electronics
    Last Post: 01-19-2013, 08:41 PM
  3. Replies: 3
    Last Post: 01-06-2013, 10:53 PM
  4. Where is rear defogger relay wire? (and trunk relay wire)
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 11-02-2011, 03:10 PM
  5. Brian Teel on this forum?... need some 97-98 harnes/pcm info.
    By Tengis in forum Off Topic Discussion
    Last Post: 12-21-2008, 03:39 AM
