Thread: headers
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 21 to 40 of 81
  1. #21 Re: headers
    Yeah in that case I would get the powerbond od balancer.
    Sent from my SAMSUNG-SM-G870A using Tapatalk
  2. #22 Re: headers
    Kemmerer, Wyoming
    if you get a 10% overdrive, the oil filter will need to be relocated, 5% doesn't take any extra work and is cheaper.
  3. #23 Re: headers
    unless they come out and measure the pulley, you can get a press on 3.4 , it looks stock, wink wink. theres one for sale in the sale section.
    headers are going to lower your boost to about 5 psi. the 3.4 will put it back around 10 psi.
    if you want to run its very best it needs to be tuned. stock tune is crap. trans tune also helps.
  4. #24 Re: headers
    Quote Originally Posted by SgtMarshal View Post
    No you just need the spacer for the oil filter adapter or you can dent the oil filter. I had an od balancer and all I used was the spacer and had no issues with leaks.
  5. #25 Re: headers
    Mar 2017
    West Virginia
    ok
    yes they do measure the supercharger pulley
    where to get the crank pully and spacer and belt
    thanks you are give me some good things
  6. #26 Re: headers
    I know zzp sells the balancer and the spacer kit, they won't tell you what belt you need and for the life of me I cannot remember what belt it was. I left the packaging from the belt in the box in the trunk so I wouldn't forget in case I ever needed a new one, and I left it in the trunk when I sold the car.
  7. #27 Re: headers
  8. #28 Re: headers
    hangover park IL
    Get an SLP 3.5" press on pulley..... it was offered through the OEM/ dealer as an upgraded trim package
    ~James~ Psychotic Gearhead
  9. #29 Re: headers
    Quote Originally Posted by Turbocharged400sbc View Post
    And some gtx badges lol
  10. #30 Re: headers
    Dec 2012
    troll land
    That is a good point.....do the rules actually say 3.8" pulley or just stock pulley?
  11. #31 Re: headers
    Mar 2017
    West Virginia
    yes it said 3.8 and they will check
  12. #32 Re: headers
    Mar 2017
    West Virginia
    i am not asking which ones to buy
    i am asking how must they help .2 or .3 et
  13. #33 Re: headers
    headers lower the boost, so a 3.8 pulley you'll see 5 psi tops, this is where the tuner comes in handy cause now the game is to turn the timing up till it starts to show kr, then back it down a bit till theres none in a second gear pull through third.
    you allowed to run e85, or race fuel?
  14. #34 Re: headers
    Mar 2017
    West Virginia
    no race gas only
    i am running 116 fuel and when i rev it to 2500 i get 6 deg of knock
  15. #35 Re: headers
    Are you revving it in park?
  16. #36 Re: headers
    May 2008
    Schuyler, NE
    If you are running 116 octane, you should never get knock. Ever.
  17. #37 Re: headers
    if you get kr revving it in neutral or park, you need a another blower, its bearings are shot and the rotors are touching, its false kr, but still cuts your timing.
    take the sc belt off, then see if you get kr when you rev it, if not, bingo new blower time.
  18. #38 Re: headers
    May 2008
    Schuyler, NE
    That doesn't mean the blower is the problem. The motor makes significantly less torque without the blower belt on.
  19. #39 Re: headers
    if you read any of anything, this is in park, revving it. tq is not a issue here dummy. a bad blower is. cause your not making any boost revving it in park are ya?
  20. #40 Re: headers
    Mar 2017
    West Virginia
    can you hear the bearings????
  1. Headers and EGR
    By snj111795 in forum Introductions/Noob Questions
    Last Post: 05-17-2015, 10:50 PM
  2. Headers vs PEM's/Dp
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-29-2010, 12:09 PM
  3. XS Power Headers Vs. SSAC Headers
    By 04CompG in forum General Tech Discussion
    Last Post: 12-02-2008, 01:12 PM
