Thread: Transmission oil flush?
Results 1 to 10 of 10
  1. #1 Transmission oil flush?
    Mar 2012
    Montreal
    Hi there
    I got a 2007 Grand Prix with 95000 km and still the stock transmission oil in it.
    Should I change it or not?
    The oil is still red and at the right level even with a right hose small leak
    Even the dealer told me not to touch it because after that it could make the transmission to work not that well.
    What do you guys think about that?
    Thanks
    Ted from Montreal,Quebec,Canada
  2. #2 Re: Transmission oil flush?
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    If the color is a bright red, and not cloudy or dark, it won't hurt.
    Have you had any issues with it shifting hard, hesitating, or taking a while to move after going from park or reverse into drive?
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  3. #3 Re: Transmission oil flush?
    I wouldn't get a "flush" but a fluid exchange is fine.
    Older style flush machines a known to kill transmissions because they push fluid through the transmission and could dislodge clutch build up and plug the valve body or other fluid flowing area's. The newer fluid exchange machines use the transmissions OWN oil pump to pump new fluid in and while sending old fluid out. They hook up the same way in both applications, just exchange machine will suck the new fluid in through the hose and push the old fluid out other return line of the cooler into a waste oil bin.
    Your other option is just suck the fluid out the dipstick tube and replace what you took out or drop the transmission pan and refill when you are done.
  4. #4 Re: Transmission oil flush?
    Oct 2014
    Frederick, MD
    Personally, dropping the pan is the best option IMO because you can get a good idea of how your transmission is doing just by looking at the magnet in the bottom of the pan.
    If you take it to a shop, make sure it's a reputable shop. Chain shops like pep boys or NAPA do terrible quality work, and charge you for things that they don't actually do, or just mess things up and give no explanation or reason.
    Try to find a locally owned shop that gets a lot of repeat customers, or take a few minutes to read through some threads on here and follow the little tips and tricks you find. It also helps to have the right tools, find a friend with experience working on cars to help you.
  5. #5 Re: Transmission oil flush?
    Mar 2012
    Montreal
    Thanks to all of you.
    I will probably just change the oil without a FLUSH .I will open the oil pan and let all the oil drops down until it stops.Also,I will change the inner filter and put back a new gasket.
    One more thing,I have a very small leak on the right side transmission hose that,even if it leaks,it do not let a oil mark on the street but before it goes worst,I will take care of it.
    By the way,all this works could be made at my dad's garage because he got a lift,yes just like a commercial work shop.
    It was built in 1980 for his school bus business( 18 small buses)
    This garage helps him to save a lot a money since then and now all the family use it for our cars.We are very lucky
    Thanks to all of you for your time
    Ted
  6. #6 Re: Transmission oil flush?
    Mar 2014
    Tucson
    Quote Originally Posted by McFLY 1990 View Post
    After you button everything up, dump a couple gallons of fluid back in. Disconnect the return line from the cooler. Run engine until you see the "new" fluid come out of the return line. Reconnect the line. Top off the fluid.
    You have now pumped out all the old, and have 100% new fluid in its place.
  7. #7 Re: Transmission oil flush?
    GTP Level Member CHI2000GTP's Avatar
    Dec 2015
    Chicago, IL
    Ted. If you're going to do the Flush, might was well go through the slight trouble of changing the transmission fluid filter, and o-ring, and maybe even thrown in a Trans-Go shift kit. Dropping that trans-pan can be a mess. Make sure you have the proper catch pan for all the fluid, plenty of rags. Shift kit + filter + fluid = $100.00.
    Link to Write Up:
    http://www.grandprixforums.net/threa...ailed-Pictures
    2000 GTP 4DR - Stock
    243,000 miles
    CHICAGO, IL
    My Car: http://www.grandprixforums.com/members-rides/103740-lukes-gtp.html#post1443981
  8. #8 Re: Transmission oil flush?
    You won't need a new gasket if you do a pan drop.
    The factory gasket is a metal and can be re-used without issue, just clean it up of course.
  9. #9 Re: Transmission oil flush?
    Oct 2014
    Frederick, MD
    Make sure to take a good look at the magnet, if the magnet is easy to see and had distinct ridges on the top, it's doing just fine. If it is a massive lump of black, and there is no clear shape to the magnet, you might want to look at the fluid more closely, try to find anything that looks like metal shavings. If you don't find any, that's a good sign.
    Might also want to take the time to put a shift kit in, 40 bucks on Amazon, it will help keep the transmission running longer, and prevent future problems.
    It's really quite simple, follow this link: http://www.grandprixforums.net/threa...ailed-Pictures
    You will notice a big difference in the shifts after the kit, and the extra springs and spacers will actually save your trans from more wear by decreasing the time it takes to complete a shift, and allowing the clutch packs to slip much less than stock, preventing them from wearing down or overheating.
    A large flat tote is useful to catch all of the trans fluid, less cleanup afterwards.
    If you do the shift kit, grab a scotch brite pad. Not necessarily needed, but recommended.
    Lastly, use the right fluid. AcDelco Dextron III or Dextron VI is the best, but usually the most expensive, it's what the factory fluid is. Most brands will work, as long as it is a Dextron III or Dextron VI specific fluid.
    Oh, and be careful when pulling the filter out, try not to break the tube off inside the trans. If it happens, vise grips work. The seal will be a royal b1tch to get out, but be gentle with it. If you scratch the inside surface of where the seal fits into, it won't seal properly. And you can re use the factory ribbed steel and rubber gasket, just check for cracks or splits on both sides.
    I think that's it. Good luck.
    Edit: yes I know I type slow...
  10. #10 Re: Transmission oil flush?
    Mar 2012
    Montreal
    Finally,I went to a transmission specialist near by and he did removing the pan and change the filter.
    My oil was between good and very good. 8 liters of brand new oil was put back in it
    It did cost me only 97$ can for the job and about 45 minutes of labor.
    For my leaking hose,He let it like it was but just remove the minor grease on it and he will check that again next year.
    Nothing to worry about soon.
    Thanks again to all of you for your time and advice.
    See you soon for another repair or maintenance problem.
    Ted
  1. Anyone know how much for a full transmission fluid flush?
    By JoePro424 in forum General Tech Discussion
    Last Post: 11-08-2014, 05:29 PM
  2. Transmission flush?
    By Nshalaby in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-26-2013, 02:24 PM
  3. Transmission flush. Yes or no?
    By Iceman83 in forum General Grand Prix Discussion
    Last Post: 02-15-2013, 11:56 AM
  4. Transmission Flush
    By Lion29GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-14-2011, 04:03 PM
  5. The Reason That Your Transmission May Act Up After a Flush
    By njbrain in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-23-2008, 07:53 AM
