Thread: One time use axle nut
Results 1 to 9 of 9
  1. #1 One time use axle nut
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    Here is a perfect example ofwhen an axle nut is considered one time use. I just put this axle in last year an now hub bearing is bad. I must have cross threaded the nut when i installed the axle, this thingwas not coming off. After a lot of heat I cut the nut off with an angle grinder. Stupid mistake now costme a new axle along with a new bearing lol
    Sent from my SM-G930V using Tapatalk
    2002 GTP Coupe, PSE supercharger ported with 3.4 pulley, Wizaired CAI, ZZP tune, AL 104's, front Plog, 3" DP, u-bend gone, hi-flo cat, W-Body tubular trailing and lateral arms, GMPP sway bars, Vogtland springs, 245/45-18 Michelin Pilot Sport AS/3 on 18x8 wheels, 42mm offset, Dual Aeroforce interceptor gauges on A-pillar pod
  2. #2 Re: One time use axle nut
    I honestly never use the new axle nut they give you with new axles, they just suck ass compared to the old OEM nut.
    The thread pitch is either slightly off or the threads are just fubar'd from the factory, re-use OEM nuts are the way to go.
  3. #3 Re: One time use axle nut
    Dec 2008
    ****'s Creek
    I was thinking about our last discussion on this in another thread and decided you were right, probably over kill buying a new axle nut. I wanted to do a quick hub replacement and fully intended to reuse the axle nut.
    That was until it wouldn't come off. I recall it went on fine, I would have swirnit wasn't crossed, but that sucker got about halfway off and stopped. I was standing on the end of a 25" breaker bar and the nut wouldn't move. Of course everybody has left axles in stock, but the only guy with a right axle is the advance 3 towns over so could not finish the job last night, picking up the axle today at lunch.
    So after I cut the nut off, i llaughed that that's about as onetime use as you can get LOL
  4. #4 Re: One time use axle nut
    hangover park IL
    **** the nuts that come with the axles.
    those are cut threads with yellow zinc. a bit of rust on the threads and you can wipe em clean off as above. i rarely see em cross threaded
    Oem are rolled threads, heat treated, armor coat plated.
    i always reuse the oem unless its completly schnockered
    stock is the fastest, stock is the bestestest
    ~James~ Psychotic Gearhead
  5. #5 Re: One time use axle nut
    Dec 2008
    ****'s Creek
    So what I am hearing/reading is that I may have F-ed this up....I recall that when I installed this axle back in August, I started the nut by hand, and you get at least a couple of turns before the locking collar engages. So I know it was not cross-threaded going on. Where I screwed up was using the impact to run the nut on until snug before using the torque wrench to the final 118 ft/lbs. Apparently the hammering from the impact gun galls the threads of the nut, axle, or both, and creates what you see in the pic. Mind you it went on smooth as silk, the damage didn't happen until I tried to remove the nut. The exposed threads outside of the nut looked fine, so I had no indication there was any issue.
    These were both CarQuest new (not reman) axles. This second one came with a big red "STOP-READ THIS FIRST" paper in the box that advised no air tools or impact guns on this nut, under any circumstances. Usually this advises against overtightening, but this specifically warned of thread damage. This was not my first choice of axle brands, but it was what was in stock locally....NAPA was out.
  6. #6 Re: One time use axle nut
    Bull Twinkies on the impact causing it. I've gunned those on and off a hundred times. Like most others mentioned...aftermarkets are much easier to see an issue with...but it wasn't from the gun unless you are exceeding 600ft lbs from the gun.
  7. #7 Re: One time use axle nut
    Dec 2008
    ****'s Creek
    No, the gun was just to spin it up so I could snug it with the torque wrench. I've done it before too....maybe it's a cheap axle. Like I said, it went on fine, and it started to come off OK, but after it unthreaded about 1/4" it just bound up and stopped. I had my 36" crow bar between the lug studs to keep the hub from turning and I wound up bending one of the studs from the torque I was applying trying to get the nut off.
    Hats off to my 25" HF breaker bar, I was jumping on that thing (I'm 275) with both feet, thought for sure it was gonna snap.
  8. #8 Re: One time use axle nut
    hangover park IL
    They are crimped nuts with soft cut threads they are not nearly as strong or durable as the OEM crimp nuts with rolled threads.
  9. #9 Re: One time use axle nut
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by Burbman View Post
    Simple as that.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. Aftermarket Stereo Install? (First Time Grand Prix Owner/ First Time Forum User)
    By Kickflip Supreme in forum Audio, Security & Visual Electronics
    Last Post: 06-23-2015, 08:58 PM
  2. Looooong time GP owner, first time GPF member
    By Brian G in forum Introductions/Noob Questions
    Last Post: 10-02-2013, 06:04 PM
  3. Axle seal - AGAIN (driver side this time)
    By SJAndrew in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-20-2012, 01:23 PM
  4. Long time owner/first time poster!
    By brez in forum Introductions/Noob Questions
    Last Post: 08-08-2011, 04:58 PM
  5. long time visitor first time poster
    By max98 in forum Introductions/Noob Questions
    Last Post: 05-20-2010, 10:50 PM
