Thread: Supercharger vs turbo
Results 1 to 20 of 26
  1. #1 Supercharger vs turbo
    GTP Level Member Dee23's Avatar
    Jul 2012
    North Philly
    Now we all know turbos make more power on these 3800s than the M90 but my question is to those who have had full out 3800 M90 builds and than swapped over to turbo for more power.
    Whats the low end power diff between the two and the take off speed diff which is quicker? I know turbos usually have more top end and superchargers are quick off the line but i just wanna here from first hand 3800 experiencers.
    Im just curious of the low end torque diff and the quickness diff between a supercharged and turbo 3800. I like that quickness off the line and or from a digg
    Not your average grocery getter, but theres always at least two things on the list.... 10w-30 Castrol Titanium and Shell 91 premium mixed with a lil 100 octane racing gas......
  2. #2 Re: Supercharger vs turbo
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    I noticed a bit of a low end difference. So I upped timing down low and installed a anti-lag. Problem solved.
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  3. #3 Re: Supercharger vs turbo
    Antioch, IL
    I didnt have a fully built m90, 3.4 and the support mods then went to turbo. Low end sucks balls cant even squeal off the line. After your done crying for 1.1 seconds of no low end it goes M90 what?
    2009 Challenger SRT8
    Expert at being gay.
  4. #4 Re: Supercharger vs turbo
    SWPA
    I've never been in a turbo 3800 but have owned, driven, been a passenger, etc in several turbo cars. I'll tell you like I've told numerous other people is that turbo lag is overstated.
  5. #5 Re: Supercharger vs turbo
    Buffalo
    Twincharged / CSC not in your list ?
  6. #6 Re: Supercharger vs turbo
    Kemmerer, Wyoming
    I had a 2.8 pulley on my GTP with ported L32 heads, xp cam, full size intercooler and a built transmission. the bottom end on the xp cam wasn't that great. I would guess the car was making about 350 hp at the wheels, and it wasn't enough. I have a turbo to put on and expect the powerband to be much better.
  7. #7 Re: Supercharger vs turbo
    Antioch, IL
    you wont ever turbo, exit the thread n/a low comp guy!
  8. #8 Re: Supercharger vs turbo
    Apr 2014
    South Haven, MI
    As someone who went from a supercharger to a turbo with an xp cam I can tell you the powerbandis awesome now lol.
  9. #9 Re: Supercharger vs turbo
    Kemmerer, Wyoming
    I think I'm going to start the install next week. hopefully it wont take too long.
  10. #10 Re: Supercharger vs turbo
    Kemmerer, Wyoming
    Quote Originally Posted by BoostedPontiac View Post
    that's what im hoping for
  11. #11 Re: Supercharger vs turbo
    May 2008
    Schuyler, NE
    It's going to depend on what turbo you go with, and quite a few other aspects.
    A turbo will not have the instant response the m90 does. You can set up an antilag to help, or brake boost, but you aren't going to sit at idle and have boost at an instant.
  12. #12 Re: Supercharger vs turbo
    Jul 2012
    North Philly
    Thanx for the honest replies. I would love the power of a turbo but i cant deny the quickness of a supercharger at any given time. And the supercharger whine is just.........music to the ears
  13. #13 Re: Supercharger vs turbo
    SE Level Member SlowFiero's Avatar
    Feb 2008
    Canada
    My turbo setup is quicker in every way at the track. 60' dropped from best of 1.54 to best of 1.42, and consistent 1.4x.
    On the street, full boost is achieved in under one second, not m90 instant, but it is so much quicker once it hits, it doesn't really matter.
    I sized everything for good response, so 6262 turbo and ST1 cam, if you use a bigger turbo and oversized cam for the engine, the response will be slower.
    Billet 6262 T3 turbo, PT1001 intercooler, ST1 cam, 140 springs, pushrods, N* TB, L26 upper, HV3, otherwise stock L32. 10.007 @ 135.54with 1.46 60' 3130 lbs
    Old GenV M90, XP, heads, N* TB, ST2 intercooler - 11.425@115.60 1.54 60'
  14. #14 Re: Supercharger vs turbo
    I break stuff selliott's Avatar
    Kansas City
    The m90 may be slightly faster off the line but it will never have the butt pucker factor of the turbo when it spools up.
  15. #15 Re: Supercharger vs turbo
    Quote Originally Posted by SlowFiero View Post
    holy hell 20mph gain on the big end according to your sig.......
    welp nothing more needs to be discussed in this thread lol!
  16. #16 Re: Supercharger vs turbo
    Feb 2008
    Canada
    It now does the same mph at the 1/8th that it did with the m90/1.9 rocker setup that I ran the first time in the 1/4 mile, 106mph lol.
    Turbo setup has been 137.x mph, with a slower ET.
  17. #17 Re: Supercharger vs turbo
    Kemmerer, Wyoming
    the technology that Eaton used when they designed the M90 was from the mid 90's, and turbo technology has come so far since then. with compressor maps all the different nozzle's available you have so many options that can dramatically reduce spool time while still making decent power. I saw a guy who twin turboed a 3800 engine in a sand rail with 30mm turbos, and that thing only made 300 hp, but it made that power at like 2000 rpms.
  18. #18 Re: Supercharger vs turbo
    hangover park IL
    With the 3800's best Muffler being a turbocharger.... the choice is plainly obvious for the best exhaust sound.
    The small 54 millimeter turbo on a buddy's Bonneville is stupid insane fast light-off....exploding off the line that he can easily Burn Rubber with an L 36 and minimal "rubber banding"
  19. #19 Re: Supercharger vs turbo
    A turbo will typically be much nicer to your trans for daily driving etc.
  20. #20 Re: Supercharger vs turbo
    Feb 2008
    Canada
    Not too sure about that, I'd run a 4340 input shaft for years with the m90, lasted a week on he street with the turbo before shattering. The 300m I replaced it with broke within 3 months of street use and two trips to the track. Killed 4 7/8" chains in that time too.
  1. conversion of a supercharger to a turbo
    By ricoswave in forum Off Topic Discussion
    Last Post: 05-20-2013, 06:15 PM
  2. Supercharger vs. Turbo
    By Trevjar in forum General Tech Discussion
    Last Post: 07-06-2012, 02:39 PM
  3. Turbo And Supercharger?
    By erichamby in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2011, 08:56 AM
  4. supercharger or turbo debate
    By 98bullit in forum Introductions/Noob Questions
    Last Post: 11-30-2009, 12:51 PM
  5. turbo or supercharger
    By grandprixgt in forum General Tech Discussion
    Last Post: 06-26-2009, 04:04 PM
