Thread: A/C acceleration
Results 1 to 5 of 5
  1. #1 A/C acceleration
    Sep 2015
    Sacramento
    So I haven't used my heater or A/C for nearly a year because of winter and long down times due to repairs.
    Recently cranked the A/C and my cars accelerating strangely. It's also making a weird noise while accelerating in the low end of each gear.
    Thoughts?
  2. #2 Re: A/C acceleration
    St. Louis
    What do you mean by "accelerating strangely"? Does it seem like it's lagging? The A/C compressor has been known to drag the motor down or even stop it from running when it starts to lock up. You could test it by removing the belt and taking it for a quick test drive. Keep in mind that the water pump and whatnot will not be working as well with the belt off and it will heat up quick so keep the drive to a minimum. If the lag and weird noise is gone then I'd check the A/C compressor as it may be on it's way out.
  3. #3 Re: A/C acceleration
    GT Level Member Jnibbs24's Avatar
    Sep 2015
    Seattle
    Get a tune they get rid of the lag, sometimes I think my car takes off quicker with the ac on
  4. #4 Re: A/C acceleration
    Sep 2015
    Sacramento
    Yeah it seems like there's lagg, less power, also it sounds like the engine is working harder.
  5. #5 Re: A/C acceleration
    ac compressor could be sh itting the bed.
  1. Slow acceleration or no acceleration
    By tierzu in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-30-2015, 01:05 AM
  2. 06 GP GT Acceleration
    By eleedy in forum General Tech Discussion
    Last Post: 02-08-2013, 01:55 PM
  3. Acceleration
    By Fivefingerdeathpunch in forum Off Topic Discussion
    Last Post: 09-25-2011, 11:18 PM
  4. New acceleration vid
    By IR II IP IDEATH in forum Off Topic Discussion
    Last Post: 11-29-2010, 01:58 PM
  5. Pop on acceleration
    By DanGTP in forum Brakes/Suspension/Chassis
    Last Post: 09-18-2008, 07:07 AM
