Thread: 99 gtp changing leaky intake gasket???
Results 1 to 9 of 9
  1. #1 99 gtp changing leaky intake gasket???
    Jan 2015
    illinois
    intake started leaking antifreeze so getting it changed.iwas just wondering if there was anything i should or could do to upgrade or preventive precaution .planning to put on a 3.5 pulley in the futurejust havent done any of the needed upgrades already have a cooler t stat but will be changing it while it is apart ?
  2. #2 Re: 99 gtp changing leaky intake gasket???
    headers, then a pulley drop, then a tune to make the most of it. return the 180 t stat, not needed.
  3. #3 Re: 99 gtp changing leaky intake gasket???
    get some metal elbows too for the shop to change with the lim. and make sure they know to seal the lim bolts with thread sealant or your leaking coolant up the threads again. why you got pools of coolant over the lim bolts now.
  4. #4 Re: 99 gtp changing leaky intake gasket???
    Jan 2015
    illinois
    thanks for the info i do appreciate the input
  5. #5 Re: 99 gtp changing leaky intake gasket???
    SE Level Member Hot wheels's Avatar
    Feb 2015
    Breckenridge TX
    Save yourself 400.00 and just do it yourself. It's not hard at all. Just take your time and keep the parts separated and take notes. GOOGLE is your friend if you get in a pinch. Also......like Scotty Doggs said....replace the plastic water elbows with aluminum ones. The plastic ones break apart and have a pick of some sort to scrape the pieces of separated plastic elbow out of the LIM
  6. #6 Re: 99 gtp changing leaky intake gasket???
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    Make sure they replace the intake gaskets with metal ones and not plastic or you'll possibly have the same problem down the road.
    I went NA when a whore left -$300 in my bank account.
  7. #7 Re: 99 gtp changing leaky intake gasket???
    SE Level Member Cordless's Avatar
    Mar 2016
    Oklahoma
    if im thinking correctly coolant runs through the tensioner assembly on those. if so i would look at replacing the coolant elbows with the aluminum ones. the plastic one are likely to break when removing them. NOE 6601942 is the napa part number and like indy said i would defiantly spend the extra money on the problem solver gaskets. im also not a big fan of dex-cool. id put green ethylene-glycol in it if it were mine.
  8. #8 Re: 99 gtp changing leaky intake gasket???
    Jan 2015
    illinois
    i already have the green i will go to metal everywhere suggested thanks again . but i will leave it to my mechanic he is about 30$ anhour
  9. #9 Re: 99 gtp changing leaky intake gasket???
    It's a 2-3 hour job and can be done with simple hand tools.
    A member from here even made this cool easy to follow video. Note he also did his lifters so you can skip that part.
  1. Leaky Leaky Oil Leak - Update.. Its the pan HELP
    By Yarbeau in forum General Tech Discussion
    Last Post: 09-17-2014, 11:27 AM
  2. intake manifold gasket or head gasket
    By Eric Whitter in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-17-2012, 01:55 AM
  3. Help is it head gasket water pump or intake gasket
    By jared71 in forum Introductions/Noob Questions
    Last Post: 02-14-2012, 01:26 PM
  4. Changing rear valve cover gasket
    By rudedude in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-26-2009, 02:20 PM
  5. changing oil pan gasket
    By ratnick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-29-2009, 08:52 PM
