Those pieces are not held in by bolts. You took your axles out to pull your trans... so you should follow the same method to get those out of ...
Wait..that trans is the one you just took out? ugh.. you took the axles apart versus taking them out of the transmission. Those are the inner cups of the CV shafts. The brown sludge is your axle grease.
I was able to get em out and reinstall in the other tran. I thought i pulled the axles the right way dam.. That was a pic of my busted trans.
Ill be going to the store soon need to get a new radiator as well. Any good suggestions? i have oreilly napa autozone and pep near by.
