Thread: Door lock issues
Results 1 to 7 of 7
  1. #1 Door lock issues
    Feb 2016
    Corpus Christi
    I have a 2005 grand prix gt. I don't have a key fob to lock or unlock doors, so I use the door handle switch. The doors always unlock when I hit the switch, but they do not always lock. However the theft deterrent still works. So, even though the doors may not lock the alarm will sound when the doors are opened. The lock switch sometimes works, just not all the time. Any suggestions on what the issue might be??
  2. #2 Re: Door lock issues
    Take it out and clean the contacts would be the easy thing, otherwise it might just be faulty and need of replacement.
  3. #3 Re: Door lock issues
    Feb 2016
    Corpus Christi
    Take what out?
  4. #4 Re: Door lock issues
    GXP Level Member
    Mar 2015
    Tomball
    Mine do something similar, but wether I lock them with the switch, the car locks or unlocks them or I use the FOB it will not completely lock or unlock them at times. I was thinking it was the individual lock, but it seems that when 1 doesn't lock all the way they all don't lock all the way. Is that what yours doing?
    Jeff
  5. #5 Re: Door lock issues
    Feb 2016
    Corpus Christi
    Jeff they will always unlock when I hit the switch. But sometimes when I push it the direction to lock the doors, they won't lock, and similar to yours they either all lock or none will.
  6. #6 Re: Door lock issues
    The switch?
    Remove the door lock/window switch assembly from the door panel and clean the contacts. Thats a free thing to do, because it seems like an electrical issue here. Either cleaning it helps or the door lock switch itself is acting up and could be replaced.
  7. #7 Re: Door lock issues
    Nov 2015
    missouri
    I would also say the contacts. The internal switch contacts become dirty or loose and start having that problem. I ended up replacing mine because they were loose and wouldn't stay working correctly
    Sent from my SM-N900T using Tapatalk
  1. tcc Lock up issues
    By theonlysi1 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-08-2015, 10:42 AM
  2. Door lock issues
    By allg32 in forum General Tech Discussion
    Last Post: 08-21-2014, 11:08 PM
  3. 2002 Grand Prix SE Door Lock Issues - Please Read Carefully.
    By 02GP4DSC in forum General Grand Prix Discussion
    Last Post: 06-30-2013, 03:58 AM
  4. Door Lock Actuator Replace - Now doors won't electronically lock
    By rmortime in forum General Tech Discussion
    Last Post: 11-17-2012, 12:37 AM
  5. remote door lock horn only when lock ?
    By NEONNIGHT34609 in forum General Tech Discussion
    Last Post: 12-10-2008, 09:05 PM
