Thread: Door lock issues
Results 1 to 2 of 2
  1. #1 Door lock issues
    Aug 2012
    Arkansas
    OK '00 GTP. all of my doors will lock with the fob or the door switch except for the drivers door. They will all unlock with the fob or the door switch. If I plug in the sensor that turns the radio off when I open the door then none of the locks will work with the fob or door switch. The horn will beep and you can here the click under the dash but nothing else happens. is it just a shorted wire? The car was wrecked when I bought it (drivers door post) and had to repair some wires that were damaged. I pulled the harness about halfway down to the drivers seat just to make sure I didn't miss anything. Everything else works so Im a little stumped.
  2. #2 Re: Door lock issues
    bad lock actuator maybe. unplug it, test for power when the switch is worked.
  1. 2002 Grand Prix SE Door Lock Issues - Please Read Carefully.
    By 02GP4DSC in forum General Grand Prix Discussion
    Last Post: 06-30-2013, 03:58 AM
  2. Door Lock Actuator Replace - Now doors won't electronically lock
    By rmortime in forum General Tech Discussion
    Last Post: 11-17-2012, 12:37 AM
  3. 04 gp gt1 door lock's
    By PALMCASTER GT1 in forum Off Topic Discussion
    Last Post: 07-06-2010, 12:48 AM
  4. Door lock help
    By toolguy in forum General Tech Discussion
    Last Post: 09-11-2009, 08:23 AM
  5. remote door lock horn only when lock ?
    By NEONNIGHT34609 in forum General Tech Discussion
    Last Post: 12-10-2008, 09:05 PM
