Thread: Thinking about servicing/upgrading my fuel injectors
Results 1 to 16 of 16
  1. #1 Thinking about servicing/upgrading my fuel injectors
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    So I ive read up on this procedure and looks simple enough. I hear enough of the guys on here talk about "60# fuel injectors" and what not.
    Ive got 175k on my ride and figured it was time to do this service anyways and saw this video and was pretty helpful to help a newb like me understand just how easy it was to do this myself!
    Replacing Fuel Injectors In Your Car - YouTube
    Anyways, since it seems easy enough to do im gonna give it a go, my question is what direction to go. I was thinking about these from ZZP
    Lucas - 42.5# Lucas Injectors #LUC-01D030B-6
    From what I understand these would be an upgrade from stock. My build does not consist of a huge HP gain, as always my main goal is Efficiency and MPGs and HP in that order. Would this be the right way to go? And while im at it should I replace the fuel rails as well?
    As always your help is greatly appreciated!
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  2. #2 Re: Thinking about servicing/upgrading my fuel injectors
    Stock injectors.
    Once you start screwing with that, its just going downhill from there.
  3. #3 Re: Thinking about servicing/upgrading my fuel injectors
    Marysville WA
    So would that be these?
    GM ACDelco - 24, 26, and 28# GM Injectors #
    Im assuming at my current mileage I should do this as its a good chance they are starting to reach the end of there life?
  4. #4 Re: Thinking about servicing/upgrading my fuel injectors
    GM ACDelco - 33# GM EV1 Injectors #GM-0280155737-6
    These are your stock injectors.
    You didn't mention your current mileage or your issues with it.
  5. #5 Re: Thinking about servicing/upgrading my fuel injectors
    Marysville WA
    Current mileage is 175K and there are no issues that leads me to believe its a problem. Im just trying to be proactive and tackle things as they come up and thought that this could be a service/mod situation.
    Quote Originally Posted by Burbman View Post
    If you are going to stay stock, just send them out and get them serviced. I did mine on both the 98 and 01 and it worked well. I used Mr. Injector in Idaho, $16 per injector gets you a pre-cleaning flow bench report, full ultrasonic cleaning, new internal sock filter, new O rings (top and bottom), new pintle, electrical test and a re-paint or exterior cleaning, all for $16 per injector plus shipping. He also flow-benches the injectors after the cleaning to insure they are balanced and sends a full report so you can see what they were before and that they are balanced now.
    You may also be able to find a local guy that can do the same. This is a much better option than buying Chinese injectors off of FleaBay,
    Im not sure if these parts come from ebay but I purchase mainly through ZZP
  6. #6 Re: Thinking about servicing/upgrading my fuel injectors
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
  7. #7 Re: Thinking about servicing/upgrading my fuel injectors
    Dec 2008
    ****'s Creek
    That link from Matt are refurb injectors from ZZP. Sounds like you send your old ones back as cores. essentially the same thing, either you buy refurbed from ZZP or send your own out to be refurbed. Difference is ZZP shows a price of $149 on their site, Mr. Injector is $16 x 6 = $96, so you save $53. Here's the report that came back with mine showing the before and after on the 01 GT:
    This is at 148K miles so definitely some varnish despite using Techron in the fuel tank once a year.
  8. #8 Re: Thinking about servicing/upgrading my fuel injectors
    53/55 is 96%
    51/55 is 93%
    Curious if compression is anywhere near as tightly grouped.
    Highly doubt it.
  9. #9 Re: Thinking about servicing/upgrading my fuel injectors
    GTP Level Member AjL227's Avatar
    IL
    I would have to agree, no need to upgrade injector size if your main concerns are efficiency and MPG.
    It does not even sound like there is a current problem. I would just drive it.
    Sending in the injectors would be nice maintenance though and benefit your fuel efficiency, if you can afford the downtime/have another vehicle.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    I too was thinking about upgrading except with a set of new 39# cobra injectors. I know a guy who has a set for $150 not sure if I should grab them or not.
    Sent using my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  11. #11 Re: Thinking about servicing/upgrading my fuel injectors
    No.
  12. #12 Re: Thinking about servicing/upgrading my fuel injectors
    Dec 2008
    ****'s Creek
    I had the car in for a LIM job, water pump, plugs/wires, some general stuff and I figured while the fuel rail is out I would send the injectors in. The injectors on the 98GT were a little worse but not much with about the same mileage. I'm not sure I would schedule it a separate job, as Matt pointed out the worst one was only at 93% efficiency. Problem is, you don't know until you send them in to be flow benched. Usually you have a drivability issue that prompts this service.
    My only point to the OP was that if he had already made up his mind to buy serviced units, that he could send his own in for servicing considerably cheaper.
    Oct 2011
    MI
    No.
    Good enough for me lol ill spend the cash somewhere else
  14. #14 Re: Thinking about servicing/upgrading my fuel injectors
    Marysville WA
    Well this is all good info, Im not looking for a ton of downtime, I do have another vehicle but sounds like my best bet is to stick with what I got. When would replacing the injectors make sense? Here is my final goals with this car.
    Headers, Cat back, Open cone, gen V ported and polished, drop pulley (the next step down just enough to make the mods worth it) Tune. And maybe a cam but I have no idea how to do that myself. Im sure I will have to address a few other things also but this is a long ways out
  15. #15 Re: Thinking about servicing/upgrading my fuel injectors
    IL
    It would "make sense" to replace the injectors when they are unable to keep up with fuel delivery, the setup you listed will be just fine with stock injectors.
    I've ran stock injectors just fine with a mild (XP) cam & I/C with a big pulley.
    It would also "make sense" to replace them if they've failed electrically, that which you would not know without injector testing.
    Send them out somewhere reputable.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  16. #16 Re: Thinking about servicing/upgrading my fuel injectors
    Marysville WA
    Thanks I think I will just run them for now and when the car starts acting up ill look into servicing them
  1. upgrading your injectors, fuel injector calculator
    By taman86 in forum General Tech Discussion
    Last Post: 03-31-2011, 01:45 AM
  2. Thinking of Selling my GTX Rims and upgrading...
    By Spartan GL in forum Tires & Wheels
    Last Post: 01-18-2011, 03:13 AM
