Thread: surging as if pumping accelerator
Results 1 to 6 of 6
  1. #1 surging as if pumping accelerator
    SE Level Member blazineagle's Avatar
    Little Rock, Arkansas, United States
    Alright, I've got an '05 Grand Prix. Today when getting off work, I hopped in my car. Now, usually I have to pump the accelerator once for it to level out and stay running when I start up. I did this, and noticed that I pumped it once and it surged as if I was pumping the accelerator 3-4 times. I threw it in drive, and it's got very little power to it. It runs as if I'm just tapping the accelerator. The RPMs get up and stay around 4.5K when I'm holding the pedal steady, but it still surges like I'm tapping and is even worse on a hill. I made it home and am a bit at a loss. Any help would be appreciated.
  2. #2 Re: surging as if pumping accelerator
    is the check engine light on?
  3. #3 Re: surging as if pumping accelerator
    Interesting. I just went out to start it and double check the light. It started and ran fine a couple times around my apartment complex. I did not pump it when starting this time. I did when starting it when it had the issue. I had plans on going out of town this weekend. Wondering if it would be wise to go ahead with that or to take my truck. It's not ever done this to me before. I had the transmission rebuilt a few months ago, replaced the serpentine belt yesterday as well as some fluids. Just want to catch the issue, if there is one, before it becomes bad/expensive.
  4. #4 Re: surging as if pumping accelerator
    Feb 2010
    TN
    I had that once took months to find it it was the positive battery cable it had shorted out and fused to the engine block
  5. #5 Re: surging as if pumping accelerator
    No, It is not.
  6. #6 Re: surging as if pumping accelerator
    Pennsylvania
    Clean MAF, throttlebody, air intake filter...
  1. accelerator seizing up
    By gearhead1001 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-29-2011, 11:00 PM
  2. Dual brake/accelerator
    By juicestain100 in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2010, 11:15 AM
  3. car cranks but wont start unless you press accelerator
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2009, 10:49 PM
  4. Fluid pumping out of vent
    By Progas in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-08-2009, 07:37 AM
  5. Accelerator cable slack?
    By dagger in forum General Tech Discussion
    Last Post: 04-07-2009, 09:09 PM
